Dual Reservoir Master Cylinder Adapter
Preface by saying I am several (wife is real proud of me at the moment) frosties into the holidays.....
Got the Toy Pitman Arm - Got the new Leaf Springs - Got the HD Tie Rod - Got The King-Pin Kit - Got The various Pedal Bushings and Springs - Brakes , Shackles etc. This is a stock front end with the Toy Box......
Need the adapter / push-rod for 67-72 Ford Dual Reservoir Master Cylinder for the Bonus Built. Sac Vintage shows $65 bones. Go to the web an it's $120...... I don't think so !
Anyone have a better source ?
Thanks
E-Dawg-a-saurus.....
Thanks
Excellent Gallery, BTW!
The round bracket looks like a steering column floor mount used when you swap from the OEM box?
I don't know for sure since my panel had already been converted when I got it, and I further converted it to hanging pedals, but I suspect the reason for the new bracket is to put the MC fill cap under the floor acess hole? Otherwise filling and checking would be very difficult?
I don't know how they justify doubling the price. Is this the same adaptor you were looking at?
It was $65 3 years ago when I purchased it. Steel prices have jumped, but not that much! This adaptor and extension rod works perfect, it steps the cylinder down enough to get the lid off, and spaces it correctly for the access hole. I just check mine from underneath and never cut out the access hole in my new floor pan. For the price I could have made one, but sometimes I take the lazy route.
It might be worth calling them to verify the price.
Thought the web-site was a miss-print. No worries, if you can sell it at that price knock yourself out. I'll fab my own.
Thanks for posting the information Scott. It also looks like it has a slot milled in the tube for push rod clearance and the hole/tube is definitely offset towards the top of the triangular bracket. The bottom of the oval bracket may be as well.
You know, this is something that I can make, I think that I'll give it a shot, as I've been wanting a dual cylinder for safety sake.
I have a new Raybestos MC36367 lined up for this project at $45.34 including shipping through Amazon.com (Corvette 1967-1976, 1" piston).
Other part numbers:
CARDONE 101371
DORMAN M36367
AC DELCO 18M27 (18030269)
Scott if I could ask a favor: Would you be able to provide any dimensions on the offset? I would appreciate it greatly.
Also, do we have any place to store a drawing on this site once I have one done?
Thanks,
Jon
Other part numbers:
CARDONE 101371
DORMAN M36367
Thanks,
Jon
Jon, I'll try to get some measurements tonight. It's a pretty basic piece, shouldn't be too hard to fab up. You are right that it has a slot milled in it for the pushrod clearance as well.
I used a mustang MC for a drum/drum system from the early 70's if I remember right. They are cheap and plentiful and pretty much any parts store has them if needed. The old original one I'd always have to go to NAPA and order kits for, with a few days down time.
