Check Engine? - Ford Truck Enthusiasts Forums
Check Engine?
Old 12-19-2008, 01:54 AM
Prozon's Avatar
Prozon Prozon is offline
Prozon has a good reputation on FTE.Prozon has a good reputation on FTE.
Check Engine?
The truck is a 1988 F-350 with a 460 CI engine.
So I changed my engine a few months ago, and I removed the smog pump and EGR valve from the new engine.
Before the engine was pulled I had the check engine light on almost constantly. I pretty much just ignored it until I was forced to pull the engine. Most of the time it was an oil low thing because it had two dead cylinders and bad rings and burned quarts of oil in NO TIME. (It still ran when it was pulled.)
Anyways, with the new engine I still have a check engine light on. I assume it is something new, but it could be an old problem popping up again.
I ran a really confusing self-tester. Some "count-the-beeps" B.S.
I THINK my codes were;
  • EGR VALVE CONTROL SENOR
  • Throttle Position Sensor out of range
  • Power steering pressure sensor switch
I don't HAVE an EGR valve anymore, could its absense be causing this problem.
I have absolutely no idea how a throttle position sensor could be out of range. Could it have been installed wrong? What could I do to remedy this?
I didn't know my power steering had a sensor. The power steering pump leaked really bad on the old engine. ( I believe it was a hose and I believe I fixed the leak. ) I have not noticed any LACK of power steering but I did notice it was making a whining sound as if it was low on fluid.
If anyone can make sense of all this junk I just typed out and has any helpful idea's let me know!
I'm going to take my truck to someone who knows what they're doing with a tester. But until then, let me know what you guys think.
Thanks
Old 12-19-2008, 09:01 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Yes if the EGR valve is missing you'll get a code, that one should be obvious. The EGR system actually improves milage and there's no way to eliminate it without getting a code so your options are limited if you want to fix this. The TPS sensor is the type that measure mechanical movement so these things don't last forever, it's very possible it is malfunctioning and needs to be replaced. Many of these trucks have a pressure sensor in the power steering line, It's not a big deal if you don't have one or have it hooked up but you'll never get rid of the check engine light if it's not connected.
Old 12-19-2008, 01:14 PM
Prozon's Avatar
So there is no way to get rid of the codes without the EGR?
Old 12-19-2008, 01:53 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
The only code here setting off the light is the EGR code. It's the only one that's emissions related. On the older (OBDI) computer it was set to only light the MIL on an emissions fault. Your engine is designed to run at optimum with the EGR installed, so reinstall it, and reset the codes. If the TPS code comes back replace the TPS.
Old 12-19-2008, 01:54 PM
Conanski's Avatar
The computer commands movement of the EGR valve via the EVR(EGR vacuum regulator), and measures the actual valve movement with the EVP(EGR valve position sensor), disabling either or both sets a code. If the complete EGR system is installed and operating correctly, but the EGR valve is blocked at the intake manifold, you won't get a code but the motor will be detonation prone because the computer adds more timing when it commands the EGR to open. This is why it's beneficial to keep this system. The only way you won't get a code and not make the motor ping is by spending $500 on a tuner to shut off the whole EGR routine inside the computer, but that's not terribly cost effective.
EGR Vacuum from Pump gregplus40 1987 - 1996 F150 & Larger F-Series Trucks 2 09-07-2009 09:43 PM
Funky Problem Nightstalker Bronco II 49 10-25-2007 01:56 PM
Studder driving me nuts... bebad96 1987 - 1996 F150 & Larger F-Series Trucks 19 07-31-2004 06:53 PM
Thermactor System?? bebad96 Ford Inline Six, 200, 250, 4.9L / 300 17 06-16-2004 01:00 AM
Vacuum leak or EGR valve stuck? - Ken00 please read! jbblevin1 Ranger & B-Series 14 05-30-2002 12:55 AM
Tags
1990, check, efi, engine, f150, ford, light
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
