stock piston size for a 92 460
Personally I wouldn't use either. They are not fixed hones, meaning they don't true a cylinder at all, they only follow whats there & can do more bad than good when used in excess. Measure the bore with a good dial bore gage. Mic the piston at the correct location to determine the clearance. If a cylinder is round to within say .0015 you probably would be ok with just zipping up and down it a cupple of times with a berry hone, assuming the skirt clearance was within specs. Anymore & I'd get it bored if you intend to keep it.
CharlieLed
09-09-2023 06:04 PM
Nick-1973-ford
01-04-2017 09:02 AM
1tim1
10-11-2008 11:15 AM
tellico racing
03-28-2003 05:22 AM
