Torque spec for axle U-bolts - Ford Truck Enthusiasts Forums
Old 07-26-2001, 10:07 AM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
What is the torque spec for installing the axle U-bolts on a '95 2WD F150 short bed with extended cab?
Old 07-26-2001, 11:16 AM
85351ho 85351ho is offline
85351ho is starting off with a positive reputation.
guys correct me if im wrong, but i think its around 150 ft lbs
1985 F-150/351Ho/c6/4wd~94,000 miles
1979 F-150extcab4x4/460/c6/6inchlift w/60rear44frnt (250 axles and spings)
37 inch boggers
Old 07-26-2001, 05:15 PM
StrangeRanger StrangeRanger is offline
StrangeRanger is starting off with a positive reputation.
The '96 shop manual says 83-113 ft-lbs.
Old 07-26-2001, 11:16 PM
i double checked , and that was the spec skyjacker gave me, so nevermind
37 inch boggers
Old 07-27-2001, 06:33 AM
TallPaul's Avatar
Well I ended up going with my '87-'88 Chilton which said 110 ft lb. Guess that fits in the range of the '96 manual (thanks Strange Ranger). Anyway, I had a used rear end installed and found some of the u-bolt nuts were right up around 100 ft lb, but others were only at around 40 ft lb. Got em all torqued up to 110. Also the diff cover bolts were so loose that it was seeping. I think this may explain the tinking noise that was in my driveline (discussed in a different post), because that seems to have gone away.
Old 07-29-2001, 05:34 PM
SHANE_2 SHANE_2 is offline
SHANE_2 is starting off with a positive reputation.
Leaf Spring to axle ubolt torque spec '94IDITurbo7.3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 25 05-14-2014 08:38 AM
Lift blocks, u-bolts, shifted rear end rfw0002 1997 - 2003 F150 3 03-09-2011 10:44 PM
rearShackle, front spring and u-bolt torque specs Neal 97 250 1999 - 2003 7.3L Power Stroke Diesel 1 12-05-2009 11:50 PM
u-bolt torque? JROB 1999 to 2016 Super Duty 2 03-13-2009 01:14 PM
Axle U-bolt Torque ??? brad3384 2004 - 2008 F150 1 06-20-2007 07:32 PM
Tags
1967, 96, axle, bolt, bolts, boults, end, f100, f150, ford, rear, spec, specs, torqe, torque, tq, ubolt, ubolts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
