Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 12-18-2008, 08:03 PM
Baumbach Baumbach is offline
Garage is empty, add now
Baumbach is starting off with a positive reputation.
Brake wear, front or rear?
I would like to know if your front are rear brakes are wearing faster than the other, normally you would replace your front brakes two-times for every one-time you replace the rear.
I now have 35k miles on my 2008 Expedition Limited, and am being told that my rear brakes are wearing faster than my front brakes.
If you own a 2007 or 2008 with over 35k miles and have had your brakes replaced, which ones did you get replaced, the front or rear???
  #2 (permalink)
Old 12-19-2008, 11:11 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Don't you have tools in the rear? Would this cause the wear? Sticking caliper?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 12-19-2008, 03:22 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
It's not un common for trucks today, under light load to use the rear brakes more then the front, this is to off set wear under heavy loads. GM SUVs and trucks have this wear pattern quite often. Our f-550s in our fleet trucks see higher rear wear then front wear. I think 35K seems a little quick but I don't know what you are hauling/towing or your driving style. I'd say you can expect to see between 40 and 80 out of 1/2 brakes and 80 to 100K on 3/4 ton brakes (majority non loaded miles). Our 20K mile expedition has about 80% brake life on it but it's all highway miles too, I mean drive 150 miles use the brakes twice and then drive another 150 and use the brakes twice kind of driving.
  #4 (permalink)
Old 12-19-2008, 05:35 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is starting off with a positive reputation.
I'm mostly in the F-150 section, but I replaced my rear brakes at about 34000 miles on my 2005 F-150. I read a thread about two months ago about this and went out in the garage and checked mine and the pads were almost gone. It must be correct that there is more rear brake bias then with the older trucks. The good part is that aside from cutting the rear rotors (which I didn't do, they weren't bad), the rear pads are very easy to replace and takes only a few minites a side to perform.
  #5 (permalink)
Old 12-19-2008, 08:05 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Just out of 35,000 mile service a couple of hours ago. Not a peep from the dealer about brake wear -- and I'm sure they could use the business!
-- Chuck
Tags
2008, 2009, brake, brakes, expedition, faster, ford, front, pads, quick, rear, truck, trucks, wear, wearing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
