33x12.5R15's on 7.5"wide rim
My 95 F150 has a 4" Procomp lift and 33x10.5R15 on the factory 10 hole aluminum 15 x 7.5"wide rims
I really like the rims and want to know if i can run the 12.5" wide tires safely on these rims
Is this dangerous or will it just prematurely wear the middle of the tires a bit?
thanks
thanks
I liked my stock 7.5" rims also and wanted to put 33x12.50x15's BFG All Terrains on them. After doing some research and making some calls I bought 15x8 rims. BFG recomends a minimum rim width of 8" for 12.50 tires. It's a safety issue and they will not honor the tire warranty if the rim is smaller.
I have 33 x 12.5 on my factory 7.5" rim. The only problem is that there is not enough back spacing so the tires hit the Radius arms at full turn. No biggie, I just don't turn as hard anymore. You could put longer studs and wheel spacers in, but I wouldn't really recommend that if you plan on going off road. Oh, by the way, I only raised my truck by 2" to fit them. I got longer coils and rear add-a-leafs from JC Whitney, then shimmed my front bumper out about 3/4". Good Luck
Karl Jett
'95 F-150 ext cab Eddie Bauer F-150 4x4
slightly worked 351, E4OD, Pro Comp MT 33's
350 hp at the rear wheel (I said slightly worked!!)
Karl Jett
