Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 12-21-2008, 11:52 AM
barebackjake's Avatar
barebackjake barebackjake is offline
barebackjake is starting off with a positive reputation.
dan at valair is workin on makin the clutches quieter, the zf is a real good transmission just a diesel makes alot of noise resonate through the transmission. i put an ati balancer on my truck and mine and the rollover got quieter. is your valair one of the 3 spring or 6 spring clutches?
__________________
97 F250HD 4x4 supercab 5sp 270k mi
4 link on air front and rear
2000 F350 CC 4x4 (wifes)
RIP CHRIS. 03/09/05
  #17 (permalink)
Old 12-21-2008, 05:33 PM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.
158 K miles on My DMF. The TO bearing is starting to make noise, but the clutch works fine.
That's a perfectly acceptable service life, IMO.
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
http://www.ford-trucks.com/user_gall...149391.520.390
  #18 (permalink)
Old 12-21-2008, 10:10 PM
RubberDuck's Avatar
RubberDuck RubberDuck is offline
Death Row Inmate #1
RubberDuck has a great reputation on FTE. RubberDuck has a great reputation on FTE. RubberDuck has a great reputation on FTE. RubberDuck has a great reputation on FTE.
Well, I'm going up to Dans on Tues. to put in a Double Disk. I suspect it's gonna be pretty noisy. LOL
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's/T.E. SD HPOP/RSB Diesel 140v IDM/1st Valair 3800# OBS Double Disk clutch/DP Tuner 2 pos. w/ custom switch/Gear Vendors OD/Good bye No.3 I'll miss you.
RIP #17
  #19 (permalink)
Old 12-22-2008, 12:55 AM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is starting off with a positive reputation.
YAY!!!!!! DUAL DISC!!!! LoL. my Valair Kevlar/Ceramic makes some noise. it used to be REALLY loud, but now that i have a few thousand miles on the clutch it has gotten a lot better. you can barely hear it anymore. i called Dan about it and he told me to add an extra quart of fluid to it so that's what i did. once the clutch gets more broke in and the hub of the clutch loosens a little it should get better. Dan also said he has seen some trucks that the noise never does go away. try the extra fluid..
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #20 (permalink)
Old 12-22-2008, 07:36 PM
Jaaaaaaackman Jaaaaaaackman is offline
Jaaaaaaackman is starting off with a positive reputation.
Quote:
Well I don't know 3 or 6 springs, Dan at Valaire choose the clutch I needed based on it being a Dumpbody , trailer towing , snow plowing work truck....... Seems to be intermittant at times just LOUD then real normal for about 30 seconds then LOUD again,,,,,,,, hope its ok......
What about that ati balancer , how much and is it an easy intall? got a pic?
__________________
95 F-350 XLT 4X4, 5 Speed, Dumpbody, 9 ft Fisher plow
97 F-250 XLT, SC ,Short box 4X4, 5 Speed,
  #21 (permalink)
Old 12-23-2008, 06:26 AM
the_old_ranger the_old_ranger is offline
the_old_ranger is starting off with a positive reputation.
well i be dad gum i had the same dad gum thing happen last week. first thing i thought was now That's tranny noise! pulled the clutch back out could not find a dad gum thing wrong. called napa, it's a precision sold by napa button clutch. anyways mark at napa says "well i be dad gum!, never had that happen!" . so he ordered me Another clutch from the same company only this was little different with the clutch design. so, stuck it not the same noise and not AS noisy but still raises hell. been driving it a week now and i be dad gum i think it was getting a little quieter today .!
gonna try some lucas in the trans and overfill it like Neal said.
let you know what happpens.
  #22 (permalink)
Old 09-10-2009, 03:36 AM
Reptar360's Avatar
Reptar360 Reptar360 is offline
Reptar360 is starting off with a positive reputation.
I just installed my Valaire. I only have 50 miles on it today. It is loud. I work swing shift and come home around midnight. I came through the neighborhood thinking I'm gonna wake everyone up. I expected noise, but not this much. I'll try the added fluid for the tranny. Maybe I'll get lucky and it will be low adding to the noise. I hope it gets quieter when broken in...I saw Castrol Mercon V at the store. Is this the best thing to fill the tranny with?
  #23 (permalink)
Old 09-10-2009, 05:02 AM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Rice Rocket Eater
Fullcrew7.3 is gaining momentum as a positive member of FTE.
I put my valair in year and a half ago. It never got any quieter until I put more oil in the tranny. It's still pretty noisy at idle, but a LOT better.
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW 3.55 gears ,cat delete, 4" exhaust, SC 1705, Stage 1 DIY sticks, Valair SMF, 203* thermostat, 3" DP, SD intercooler, 17* HPOP, 37/12.50/16.5's and some more stuff
  #24 (permalink)
Old 09-11-2009, 03:21 AM
Reptar360's Avatar
Today I topped up the tranny. It was low and I overfilled by 1 qt. The noise didn't bother me as much today. I notice I'm changing driving style to avoid the really noisy spot. The clutch is starting to smooth out on engagement now. This setup really transmits the engine noise. I wonder if balancing the flywheel with pressure plate would improve the general running noise.
  #25 (permalink)
Old 09-11-2009, 08:10 AM
Lanny Sutton Lanny Sutton is offline
Lanny Sutton is starting off with a positive reputation.
My Valair makes twice the noise as the Luk 07-171 it replaced.
__________________
Still clinging to my guns & religion!!!!!
  #26 (permalink)
Old 10-31-2009, 07:00 PM
Quote:
.................but 5 qts of synthetic tranny fluid sure did quieten it. Now I can hear the ole' lady complaining from the passenger seat.
__________________
Tags
3800 , 97 , bearing , clutch , disk , double , f250 , f350 , loud , noise , obs , smf , transmission , valair , zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
