Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-18-2008, 12:45 PM
mustangman mustangman is offline
mustangman is starting off with a positive reputation.
2.3 blocks with DISignition convert to duraspark?
was wondering if the 91-93 mustangs with DIS ignition2.3 blocks can be converted to distributor,i know they have a sensorplug? where the distribitorhole is, was wondering if the auxiliary shaft has a gear to convert back to duraspark using a distributor,,have a chance to pick up on these blocks thanks
  #2 (permalink)
Old 12-19-2008, 10:40 AM
TigerDan's Avatar
TigerDan TigerDan is online now
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
I believe so, but even if not, it's easy to change the aux. shaft. As long as the block itself has the hole machined for the dist. then it's doable.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 12-22-2008, 07:39 PM
Old Rob Old Rob is offline
Old Rob is starting off with a positive reputation.
The aux shaft has the gear on it. That piece that plugs the hole also has a gear on it and it drives the oil pump. There is no fuel pump lobe, so if you are planning on opening the fuel pump boss, you will need to get an earlier aux shaft.
Why would you want to go to a Duraspark and what are you planning for the extra 4 plugs?
  #4 (permalink)
Old 01-26-2009, 07:32 PM
thanks for the replies,i would use the duraspark but with an earlier 4 plug head, i have 3 efi mustangs right now but i wanted to mess with a carbed version with the carb adapter that bolts on to the efi intake,,just experimenting to make it simple,,there is a method running a 4 pin gm module with the duraspark distributor,suppose to give it a longer dwell with use of a the ford tfi ignition coil, will post later got to run
  #5 (permalink)
Old 01-26-2009, 08:55 PM
TigerDan's Avatar
1968 Ford F-250
Yes, I've read about that. I have one of those GM mudules, been planning to put it on the Duraspark setup I have in my '68 F250, just haven't gotten around to it yet.
__________________
FTE Moderator
  #6 (permalink)
Old 01-28-2009, 01:54 AM
Use the TFI I module with the duraspark dist. It puts out a better signal to the coil. I've run both with E coils and earlier stock / aftermarket coils and the TFI I was more reliable. Both are easy to wire and give you the advantage of a centrifical curve vs the locked TFI IV in non computer set up.
  #7 (permalink)
Old 02-06-2009, 12:14 PM
Quote:
thanks Rob! I did a search on using the efi original distributor and running carb, i found the wiring instructions at www.4m.net in the ministock tech section searching under "ford wiring" topic ,,,love the tough little ohc2.3!
Tags
23 , distributor , duraspark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
