i bought a sts turbo kit for a f150 and modified it to go in a f250 this was the easy part.then i put bigger injectors in which came with the kit. then we tried to flash the cpu with a tune from diablosport .the tune was all wrong but we got it running .
found a guy that said he could tune it on the dyno and we started tuning ,the first reading was 103 bhp at the
wheels he keep-
ed changing stuff on his laptop on the 80th run we had pulled 244bhp this is great but than the next run it was going good and then the gearbox started to flare (free rev). we stopped at this point changed some stuff back but keep doing it .
we took it for a drive it would go in to 1st and in to 2nd no problem but when you put in drive it would surge between 2nd and 3rd gear .
so at this stage we thought it must have busted the gearbox so i got a new one completely done all the tuff stuff in it new converter .
put it back in and it is still doing the same thing.
i am having trouble with the maf sensor getting dirty can the fam do weird stuff like what i am talking about ,or is it more the cpu has died
and is their a
aftermarket cpu that would run this motor and gearbox with a map sensor instead of a maf sensor.
