Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-17-2008, 09:57 PM
JMKiser JMKiser is offline
JMKiser is starting off with a positive reputation.
High Idle Concern
I have an issue with extreme high initial idle at start up. I took my 1998 Ranger with a 3.0L to the local dealer to have some work done about a month ago. Long story short, my number six plug wire got burned against the exhaust rail.
Anyway, I guess they re-flashed the computer to the newest *.bin, or flash version. After that when I start the truck the tachometer jumps up to 2200 – 2300 RPM and then it settles’ down to about 1500 after a moment or two, then it finally adjusts itself to about 1100 for a few more seconds and eventually ends up at 900 – 1000 RPM.
I confronted Ford about this and they said that Ranger’s and F-150’s do have a tendency to do that at start up. Ordinarily I wouldn’t be too concerned, however I believe that the 2200 – 2300 RPM high idle at start up at 0°F in Alaska is a bit much.
If anyone out there joins my concern, please point me in the right direction.
Regards,
John from Alaska….
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
