Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-17-2008, 08:04 PM
ziggyzd's Avatar
ziggyzd ziggyzd is offline
Obama.....seriously?
ziggyzd is starting off with a positive reputation.
Talking Built 302 looking for more
I have....
302/ 306ci
trick flow twisted wedge 61cc heads
D.S.S. forged -3cc flycut pistons
stock crank and rods
Every single, solitary, bolt is ARP
Trick flow cam
cam specs:
Hydraulic roller tappet
Basic Operating RPM Range: 2,500-6,000
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 232
Duration at 050 inch Lift: 224 int./232 exh.
Advertised Intake Duration: 286
Advertised Exhaust Duration: 294
Advertised Duration: 286 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.542 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.542 int./0.563 exh. lift
motor also has full msd ignition, Demon 625 carb, bbk shorty headers, edelbrock performer air gap manifold, Crane roller rockers, chromoly push rods, stiffer springs, ect ect (ask if you need more info)
My compression ratio is currently 10.25 :1
To run a supercharger on the motor as it sits, how much boost could i safely get away with?
What would i need to replace, if anything?
Can i jet my carb big enough to suffice or should i get a bigger carb?
Without changing pistons, what is the best way to lower my compression? rods, stroke it, ect.
Im looking at a mass airflow injection system too
Finally what is the best route to go on brands, kits ect. I want a centrifugal- type blower.
__________________
1973 F100- 306ci Windsor, Trick Flow Twisted Wedge 61cc heads, Crane roller rockers, MSD billet, Edelbrock performer air-gap, D.S.S. forged pistons, Lunati Cam, ATI Tranny, Ceramic coated shortys, DEMON Carb 625, March Performance Serpentine, Power Master alternator, 21" travel front, 18" rear, Fox Coilovers & Shox
So-Cal Chapter Member
  #2 (permalink)
Old 12-17-2008, 09:13 PM
ziggyzd's Avatar
bump....bump.....
__________________
  #3 (permalink)
Old 01-01-2009, 12:11 AM
quikcobra quikcobra is offline
quikcobra is starting off with a positive reputation.
they sell cheap turbo kits for the motors try that route
  #4 (permalink)
Old 01-01-2009, 10:52 AM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
1987 Ford F-250
Franken-Truck has a good reputation on FTE. Franken-Truck has a good reputation on FTE. Franken-Truck has a good reputation on FTE.
Can you get away with ANY boost at all?
__________________
Steve
2004 F150 STX
1978 F-250 4X4
1987 F-250 4x4
VIRGINIA CHAPTER
Virginia Chapter Website
  #5 (permalink)
Old 02-17-2009, 12:14 PM
ziggyzd's Avatar
i could get away with 6 psi, or so im told. sorry its been awile, this thread seemed dead
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
