inertia fuel shut-off switch - Ford Truck Enthusiasts Forums
Old 12-17-2008, 06:49 PM
tunker tunker is offline
tunker is starting off with a positive reputation.
Can anyone tell me where the inertia fuel shut-off switch is located on a 1999 Ford Explorer ? Also, if I reset this button, which would happen after airbags have been deployed, will the vehicle then start ?
Thank you, tunker
Old 12-19-2008, 01:15 AM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
My 97 has an idiot light on the dash to tell me if the inertia switch is open & needs to be reset. Is the light on?
Your owners manual will give the location of the inertia switch. On my 97 it's under the dash on the passenger side.
Old 12-19-2008, 04:44 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
When you turn the key to the ON position, you should hear the fuel pump prime for a second or 2. If you don't hear it, then the intertia switch may be tripped. The switch on my 95 is located on the passenger foot area near the firewall. You have to peel back the carpet to see it.
Old 12-22-2008, 09:51 AM
caseys's Avatar
caseys caseys is offline
caseys has a good reputation on FTE.caseys has a good reputation on FTE.
Quote:
Thank you, tunker
Did your airbags deploy?
Old 12-22-2008, 01:10 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
The air bags and the inertia switch could both be activated in a crash but one has nothing to do with the other. The inertia switch should be in the foot area of the passenger side. Look from the kick panel around to the console and you'll find it. Mr.87 XLT, you have an idiot light for the inertia switch? I don't have an Explorer yet but I've never seen that before........
1994 Turbo IDI wont' shut off. Project IDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 05-03-2014 07:05 PM
Fuel shut-off relay R. Ferrell 1987 - 1996 F150 & Larger F-Series Trucks 0 08-09-2013 09:23 PM
manual fuel shut-off? 460/5 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 87 01-28-2010 06:47 PM
Where is the inertia switch (fuel pump shut off) located on a 2006? helper auto 1999 to 2016 Super Duty 2 06-17-2007 10:58 PM
Location of Fuel Shut-off Switch in 1991 Ford E-350 brwnk1 1987 - 1996 F150 & Larger F-Series Trucks 2 10-25-2002 04:31 PM
Tags
1995, 1999, 91, button, exlporer, explorer, f150, ford, fuel, inertia, location, shut, sport, switch, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
