Cardboard In Front Of Radiator
Unless you're running a big rig, blocking airflow to the radiator is generally NOT a good idea. Other components in the engine bay are cooled by airflow. Block the airflow, and the cooling effect is gone. I'm thinking mostly of the electrical components (like the alternator) in this situation.
on
Blocking the radiator won't do jack to help warm up times. The whole purpose of a thermostat controlled system like ours is that there is no coolant flow through the radiator unless the engine is up to temp and the thermostat opens. Until the engine is at temp the radiator isn't cooling anything.
on
It may but if your stat is working correctly the effect is due to airflow around the engine itself being reduced. And at really cold temps you could certainly cool the engine just with airflow around the block.
i agree with a benefit when running 70 on the interstate with no load, i dont normally run anything on the front of my truck iv done cardbord before and it started deteriorating pretty quickly. iv wanted to get one of the soft covers like posted above, there has been one on my truck before as it already has the one side of the snaps on the grill
I've been thinking about this as well... I'm going to do the 203 first... It's taken priority over everything right now.
but, I've been talking to another guy who blocks off his grill for aerodynamics, and he tells me, (on his sooperdudy) he can block off 60% of his grill w/out affecting cooling... food for thought.
definately leave your tranny cooler open though...
