Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-17-2008, 12:44 PM
64F-100's Avatar
64F-100 64F-100 is offline
64F-100 is starting off with a positive reputation.
Cracked Head?
The 292 in my 64 F-100 starting missing pretty bad. I determined that the cause was fouled plugs due to bad valve seals. Started replacing valve seals (they were like bakelite) and got to the second last cylinder and when I plugged in the air hose to keep the valves up, I heard gurgling...I'm hoping it is just a blown head gasket; the spark plug from that cylinder had white oil all over it, but the crankcase oil and all the other plugs look normal.
Are the Y-blocks known for having cracked heads? I plan on having it pressure tested when I pull it off, just wondering if a crack is likely.
I'm pretty sure this engine only has 24K miles on it. It has sat for a while.
__________________
Balz
1964 F-100 V8 4spd
2003 Thunderbird Roadster
1974 Ford LGT 145 Garden Tractor
  #2 (permalink)
Old 12-17-2008, 09:36 PM
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
They arent "known" for cracked heads, but it does happen. If it ends up being cracked dont worry too much. A used replacement should be able to be found for $25-$50. I have three sets of the C1TEs here, but you are a long ways away.
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #3 (permalink)
Old 12-18-2008, 07:33 AM
64F-100's Avatar
Thanks - I'm going to pull it tommorrow and see what's going on.
__________________
Balz
1964 F-100 V8 4spd
  #4 (permalink)
Old 12-18-2008, 08:59 AM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 is starting off with a positive reputation.
If its cracked I'm sure I have a C1TE here for $50.00 I'm in Akron ,Ohio
Kevin Bigwin
__________________
1956 Custom Cab Big Window. 272 Y block 3sp. See gallery. Kevin
  #5 (permalink)
Old 12-19-2008, 05:59 PM
64F-100's Avatar
I pulled the head off today and took it to the shop for a pressure check. The head, block and gasket all look good, so there is something going on that I can't see. I'll know if I need another head on Monday or Tuesday.
__________________
Balz
1964 F-100 V8 4spd
  #6 (permalink)
Old 12-27-2008, 05:59 PM
64F-100's Avatar
Turns out the head is OK. Looks like I just had a leaking head gasket. When I pulled the head I thought I'd see a definite "blow-out", but it only looks like some discoloration. Going to get a valve job and put her back together.
__________________
Balz
1964 F-100 V8 4spd
  #7 (permalink)
Old 12-27-2008, 07:06 PM
Good news, glad to hear it. FYI. ARP recommends tightening their bolts or studs three times to be sure the gasket's compression ring, which goes around the cylinder, fully compresses. Bring them to torque spec, then loosen, retorque, 3 times. It may be a good idea for stock bolts too. I had a case where I torqued down a head with stock grade 8 bolts, to 73 ft. lbs, one time. Came back two weeks later to remove head and the breakaway torque of the bolts ranged from 55 lbs to maybe 60. Everyone said it must be the bolts stretching, but I am 90% sure it was the gasket which didnt fully compress on the first torquing.
__________________
1990 Ranger 4WD
  #8 (permalink)
Old 12-29-2008, 07:52 AM
64F-100's Avatar
That's good information - Thanks. Should I check the torque again after I run the engine for a while?
__________________
Balz
1964 F-100 V8 4spd
  #9 (permalink)
Old 12-29-2008, 11:17 AM
Felpro says no, not necessary. But it cant hurt.
__________________
1990 Ranger 4WD
  #10 (permalink)
Old 01-02-2009, 11:23 AM
64F-100's Avatar
Thanks -I'll check them once I run it for a while. That is, if the machine shop ever gets done with my heads!
One other note on the different length head bolts: I took note of where the longer head bolts were as I unbolted the heads, and on the pass side, the two longest ones were next to each other at the back end of the motor. ON the driver side, the two longest were next to each other at the front end of the motor.
Everything I have read in this forum says that the two longer bolts are at each end, (i.e. one at front of motor and one at back of motor).
Maybe I am misinterpreting.
__________________
Balz
1964 F-100 V8 4spd
  #11 (permalink)
Old 01-02-2009, 07:19 PM
No misinterpretation. Longer on the ends, through the dowels. Whoever put the heads on previously screwed up. That is probably the reason for the gasket leak(s), because two bolts were bottomed out, unable to be torqued down properly.
Take a looks at John Mummert's section regarding Y block assembly errors, since you are getting closer to being a "motorhead" .
Concerning the installation of intake gasket and manifold. I am going to try this on my installation soon. Light coat of white grease on head and manifold surfaces, no sealer. RTV around each water port, head and manifold surfaces. Ted Eaton said he uses the grease when dyno testing an engine. It allows installation and removal of manifold without messing up gasket. Others have said they use no sealer or anything else except in the area of the water ports. I have always used sealer on the entire gasket, and when it is time to remove there is a mess that takes time to clean up.
__________________
1990 Ranger 4WD
  #12 (permalink)
Old 01-02-2009, 08:22 PM
64F-100's Avatar
OK - I did take a look at the assembly errors section - Good stuff in there. The machine shop said my heads will be done tommorrow AM, and its supposed to be 45 degrees and no rain here in Cincy tomorrow so I should have the old 292 running by tommorrow evening. I'll post an update with my results on Sunday.
Thanks for all the help!
__________________
Balz
1964 F-100 V8 4spd
  #13 (permalink)
Old 01-04-2009, 10:44 AM
64F-100's Avatar
UPDATE - A buddy and I got the engine back together last night with no leftover parts! Fired it up, and it ran like crap. We adjusted on the valves for a while (using feeler guage) and got it to smooth out quite a bit, but the engine still vibrates alot like it has a miss (runs better than before though). Using the finger-meter, we noticed that the cylinder which previously had a compression leak seemed to be running a little cooler that the rest, judging by the heat coming from the exhaust manifold.
This morning, I read up on how to adjust the valves using the quarter-turn method. I am going to try that today and see if that gets it to smooth out...Also going to check the compression on that cylinder to see if it still leaks.
__________________
Balz
1964 F-100 V8 4spd
  #14 (permalink)
Old 01-04-2009, 02:32 PM
64F-100's Avatar
Did a compression test on the suspect cylinder...0 psi and oil all over the plug. The rest are between 100 and 110 psi.
Guess it's time for a re-build. At least I got new heads now...
__________________
Balz
1964 F-100 V8 4spd
  #15 (permalink)
Old 01-04-2009, 06:33 PM
Uh Oh. Zero psi...perhaps one or both valves arent closing at all due to a mistake in the lash adjustment.
__________________
1990 Ranger 4WD
Tags
145 , 18h , 1974 , ford , gardan , lgt , tractor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
