Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 01-04-2009, 08:13 PM
64F-100's Avatar
64F-100 64F-100 is offline
64F-100 is starting off with a positive reputation.
I'm thinking maybe a ring is broken, because oil got all over the compression tester fitting.
I'm thinking maybe I can just drop the oil pan, carefully remove the rod cap and push the piston/rod out through the top of the motor, re-ring it and put it back together. Maybe it will run good for another year or so. That seems like my cheapest option right now.
__________________
Balz
1964 F-100 V8 4spd
2003 Thunderbird Roadster
1974 Ford LGT 145 Garden Tractor
  #17 (permalink)
Old 01-04-2009, 10:13 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
It sounds like a good plan. If there is much of a wear ring at top you may have to grind that down. Sometimes the rings are stuck and it isnt required. Most auto stores loan or rent the grinder for not much, if it is necessary. Dont get carried away and remove an excess amount of material, and try to get as much debris out as possible. What size rings do you need. I have some cast .060 OS on hand.
__________________
COLOR=Navy]1946 1/2 ton with Y-block
1964 F-250, 292 4 speeed
1990 Ranger 4WD
  #18 (permalink)
Old 01-05-2009, 07:29 AM
64F-100's Avatar
Not sure which rings I need. Stock ones I guess. I don't think the motor has ever been bored out.
There is about a .030" lip at the top of the cylinder (same as the others), and a small scuf mark on the cylinder wall. You can barely feel it. I guess I can hone the cylinder and take care of that.
__________________
Balz
1964 F-100 V8 4spd
Tags
145 , 18h , 1974 , ford , gardan , lgt , tractor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
