Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-16-2008, 10:36 PM
4netbronco 4netbronco is offline
4netbronco is starting off with a positive reputation.
spool in 71 bronco
ok, i wanna put a full spool in my 71 bronco with a 302, i wanna put the spool in both the front dana 44 and the rear ford 9''.. i plan to have 33x12.50 super swamper boggers.. i have over 400 horsepower and this is strickly offroad.. how well will this perform??
  #2 (permalink)
Old 12-17-2008, 09:43 PM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
In the mud it will be awesome... Generally offroad it will be good. If you are going to do rocks with those rears you will probably break something if all you have is a spool.
  #3 (permalink)
Old 12-18-2008, 11:43 AM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
Would be a good idea to upgrade to 31 or even 35 spline axles and upgrade to the spool at the same time. Better than breaking axles and having to buy the spool twice.
I run a Detroit in the rear of mine, but have driven it both ways. The spool is more predictable in slippery situations. The Detroit tends to lock and unlock at inconvenient times and causing a direction change.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
