I am going to use a Race Pro cross flow universal aluminum 2 row radiator. 22X19 tall. It fits with side brackets tig welded to the tanks to mount to stock radiator frame. There was an issue with the bottom outlet being excessively long and angled straigt towards my water pump (292 Ford). Worked it out. There still is a problem with the very top corners of the radiator slightly interfering with the conelike cowl that holds the hood latch. Probably will deal with that by eliminating the stock cowl, and fabbing a flat aluminum cover and a different hood latch.
The radiator was reasonable, around $175. I messed around with quite a few different radiator hoses though, adding up to $90. Welding $75. Overflow tank $25.00. 1/2 inc. thick Neoprene base $20. Time: a lot!
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
