351w vs. 351c - Ford Truck Enthusiasts Forums
351w vs. 351c
Old 12-16-2008, 10:15 AM
sedly's Avatar
sedly sedly is offline
sedly is gaining momentum as a positive member of FTE.sedly is gaining momentum as a positive member of FTE.
351w vs. 351c
Is either of these engines more desireable than the other?
Old 12-16-2008, 10:32 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
The 351c was only available for a very short time back in the early '70, but it was always a high output motor, so it is desirable for that reason. The low po 351M is often confused with the C because they look very similar, the 351C was never factory installed in trucks.
The 351w essentially picked up where the C left off and became one of the most common motors found in ford vehicles until the modular v8's were introduced in the '90's. It was built with both carb and EFI induction, and thanks to the popularity of the '90's mustang there are literally thousands of aftermarket high performance products available for the Windsor family of motors. For that reason this engine is also very desirable.
Old 12-16-2008, 10:38 AM
sedly's Avatar
i recently purchased a '79 F150 4x2 Flareside automatic with the 351w.(re-built).
I'm impressed to here about all the aftermarket part's available.
Old 12-20-2008, 06:28 PM
1dieselman's Avatar
1dieselman 1dieselman is offline
1dieselman is starting off with a positive reputation.
The 351c was built from 70-73 in a 2 barrel and 4 barrel version. Great engines the 2 barrel was best for street the 4 barrel loved to drag race. The 351w has been around 68 (I think that was first year) but the 69 4 barrel was the most desirable for most. Did you know that 351w could be built to 440 ci but the 392/393 is much more street able. I'm a big fan of both 351s even have one in my jeep cj.
Old 12-21-2008, 11:17 PM
Systems2000 Systems2000 is offline
Systems2000 is starting off with a positive reputation.
Starting in 1974, Ford replaced the 351C with a 351M. This engine was built for the smog requirements of CA (1st generation).
Ford 335 engine - Wikipedia, the free encyclopedia
Old 12-21-2008, 11:44 PM
In 1974 Ford replaced the 351C with a 351M. This was done to fullfill the 1st generation smog requirements of CA.
Old 12-22-2008, 09:08 PM
393STROKER's Avatar
393STROKER 393STROKER is offline
393STROKER is starting off with a positive reputation.
Ultimatly you can get more perfomance from the 351c, but w/ the availability of aluminun after market heads and other parts availability for the 351w now, the 351w would be your best avenue of approach for the $
Old 12-22-2008, 10:57 PM
sckootter16's Avatar
sckootter16 sckootter16 is offline
sckootter16 is starting off with a positive reputation.
what about building a clevor a winsor with cleveland heads what could you expect out of that engine and are those engine good for tourqe which I am thinking of building to put in a pulling truck stock class.
Old 12-22-2008, 11:32 PM
393STROKER's Avatar
If you change the heads would it still be concidered stock? I got Clevelands and Windsors. The Cleveland 4 bbl. is made for high rpm due to it`s big block chevy sized intake valves and big{and I mean you can stick your hand in there} intake ports. If I was building a pullin` truck I`d go big block. There`s no replacement for displacement,ask any girl.
Old 12-24-2008, 11:46 AM
1dieselman's Avatar
A clevor engine is kinda cool, I did one several years ago using the 2V heads and B&A intake. With 10-1 compression boy would that thing run. It would confuse the hell out of everyone when you popped the hood.
Old 12-24-2008, 12:24 PM
court1100f court1100f is offline
court1100f is gaining momentum as a positive member of FTE.court1100f is gaining momentum as a positive member of FTE.
Quote:
is that 440Cid using a stock engine block???? I ask because Dart Castings produces their Iron Eagle blocks that come in both Aluminum and Iron and with the main journal and deck heights of both the cleveland or windsor to suite your needs and max Recommended displacement is 462Cid(Aluminum) and 468Cid(Iron) although you could probly stretch either out to a 470Cid I'd think and not jeapardize the engines structural integrity too much......Granted I know the average joe doesn't want to spend the $$$$ for one of the aftermarket blocks but still..............thats the perfect solution to a vehicle that was only designed for a small block E.G. pre 67 Mustang or the Ford Maverick/Mercury Comet lines where a 351W would fit and hell even the 69 2 Barrel put out good power I think it was like 250HP Stock with a 2 barrel if your talking about a Ford Small Block V8 I'd go with the 351W for the sheer versatility of it and as has already been mentioned the huge aftermarket support for it..............OH yeah by the way those Iron Eagle blocks are also 4 bolt mains
Old 12-24-2008, 12:27 PM
What alls involved in making this Hybrid???? is it just redrilling the bolt holes for the heads or is it more involved than that??? I find the prospect of this configuration intriguing
Old 12-24-2008, 07:56 PM
1dieselman's Avatar
Yes 440ci from a stock block but that's where it ends. Special crank, rods and piston's. I haven't built one to 440ci but I am in the middle building one 393ci. Eagle crank 351w rods and 302 pistons with .030 overbore. Check out eagle specialty products, I think it's eaglerod.com As for the clevor engine the Cleveland heads bolt right on the windsor block but you have to drill water passages into the head,some where around here I have the instructions for that. Also requires a special intake made by B&A (i don't think anyone else made the intake) and at one time there was special spacers around that would let you adapt a windsor intake but the B&A intake was much better.
Old 12-24-2008, 08:08 PM
Hmm Why oversized 302 Pistons as apposed 351w Oversized pistons or is it just a preference???..........What stroke do you need to hit 440Cid and how much of an overbore??? Would you say that taking it to this extreme displacement with the OEM block would compromise the engines structural integrity and life expectancy???? I'm not being rude or anything I love this sort of stuff
Old 12-24-2008, 08:49 PM
1dieselman's Avatar
Because with the stroke of the eagle crank it would put windsor pistons out the top of the block, the wrist pins of a 302 pistons are higher in the piston. I don't know the specs right off hand for the 440ci, from what I have heard the stock block does fine for street and some drag racing but would want to move up to a aftermarket block for all out racing. There are several other ci configurations from the windsor block but I settled on the 393 because it was most affordable and will easily make over 400 hp in a mild setup.
351M or 351C warecreek 1961 - 1966 F-100 & Larger F-Series Trucks 7 01-25-2006 10:08 AM
351c - 351w - 351m differences gettler 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 42 05-25-2004 10:25 PM
351 HO questions Quantrex Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 09-01-2002 09:03 PM
351m vs 351w vs 351 c carp1 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 9 08-08-2001 10:58 PM
wheel backspacing shadetree351 1978 - 1996 Big Bronco 3 06-13-2001 07:20 AM
Tags
1990, 351c, 351w, f250
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
