Thanks,
I haven't seen anything like that on the back of this engine, or crawled under it to look for something, but there some other odd components I can get to from the top I yet to check my air
brakes manual to figure out what they are and if suitable to add something to the lines.
But, I also haven't had any problems since, and run a few times in as cold a weather. But not shutting down till after the compressor cycles and pops off the excess pressure and maybe the excess moisture that I think was creating the problem.
Looks like I have a Bendix AD-2 air dryer already, probably just needs a new cartridge or other servicing.... eventually.
It looking pretty old to the point It'll probably need a new bracket and fittings taking it off to service if I have problems, or end up needing to replace the entire unit and air lines to it,......or just stick a heater under it if it screws up again.
