Spare tire hanger - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Spare tire hanger
Old 12-16-2008, 07:06 AM
Zip's Avatar
Zip Zip is offline
Posting Legend
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
Spare tire hanger
I have an 03 Crewcab and I don't think I have the tools (for lack of a better term) for lowering the spare. I may have missed it but my thought is that it should be behind the back seat or is it hidden in some other strategic spot.
Old 12-16-2008, 07:40 AM
DavidB DavidB is offline
DavidB is gaining momentum as a positive member of FTE.DavidB is gaining momentum as a positive member of FTE.
jack handle?
If it is like my 2000 350, look under the hood (jack handle) and look in the glove box for the "key".
Old 12-16-2008, 08:23 AM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Hopefully one of the sponsors will chime in but,
What is the process to get a year/vin specific key for the spare winch? I seem to have misplaced mine when I dampened my interior.
Old 12-16-2008, 08:40 AM
skunk250's Avatar
skunk250 skunk250 is offline
skunk250 is starting off with a positive reputation.
in my 2007 the key is in a pouch located in the glove compartment.
Not sure how to order replacements thought. I imagine that the stealership is a good place to start.
Old 12-16-2008, 10:52 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
If you are one of the smart ones and filled out the registration card that came with the key, getting a new one is rather easy.
If you're like the rest of us, then you'll need to visit your local dealer and let them try their assortment of keys so they can sell you the correct one.
Old 12-16-2008, 03:29 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Strangely enough I still have the key. Had to knock the one out on my old 99. The rods are not under the hood in the same spot above the fan where my 99 had them. I think I may be SOL. I tried a couple wreckers in the area and no luck.
I'm sure I could use the rods from some other Ford model. Maybe I should widen my search first.
Old 12-17-2008, 02:54 PM
Saleenguy's Avatar
Saleenguy Saleenguy is offline
Saleenguy has a very good reputation on FTE.Saleenguy has a very good reputation on FTE.Saleenguy has a very good reputation on FTE.Saleenguy has a very good reputation on FTE.
Try your local autowreckers.
I bet they have them, and fairly cheaply.
Old 12-17-2008, 03:11 PM
skoveng skoveng is offline
skoveng is gaining momentum as a positive member of FTE.
You may not even need the key. My '03 XL Crew came with the key. I went to drop the spare and could not get it to engage. After trying for about an half hour I just tried the jack cank without the key. Turns out the type of spare winch on the truck did not need the key. The straight end of the jack crank just fit and lowered.
Old 12-17-2008, 03:55 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Quote:
Problem is I have the key but not the rest.
Old 12-17-2008, 03:58 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Been to two in Penticton and nada. Going to have to try the coast and Kelowna. They tell me they go like hotcakes. From experience of buying wrecker part they aint gonna be cheap. Probably be lucky if I get one for less than $50.00. Mind you any Ford truck that has the hanger should have the same rods.
Old 12-17-2008, 07:23 PM
Saleenguy's Avatar
Quote:
Do you want me to check locally for you?
If so and you want them I can buy and ship them to you, and you can just repay me.
Old 12-17-2008, 07:46 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Thanks for the offer. I'm going to make a couple calls and see what I can come up with. If I come up dry I'll let you know.
This is what I'm looking for minus the jack.
01-08 FORD F-250 SUPERDUTY TRUCK OEM TIRE JACK & IRON - (eBay.ca item 380090909196 end time 24-Dec-08 16:24:36 EST)
Old 12-18-2008, 08:00 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
In my 07 the pouch was behind my driver side back seat bolted into the plastic tray with a T shaped bolt so you could turn it by hand. Right now it's in my storage garage because I forgot to put it in my toolbox
Does spare have tpms? Anomic 1999 to 2016 Super Duty 8 01-26-2014 06:10 PM
Spare tire vs rear tank SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 16 06-22-2011 09:44 AM
top mount spare URDADDY 2004 - 2008 F150 10 01-31-2011 08:14 PM
largest spare tire in stock location? jlmotox 1999 to 2016 Super Duty 14 02-10-2010 09:57 PM
Aftermarket Spare Tire Carrier willport 1978 - 1996 Big Bronco 1 08-12-2000 06:32 PM
Tags
2002, 2004, duty, explorer, ford, hanger, heavy, jack, ranger, spare, storage, super, tire, tool, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
