Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-15-2008, 10:20 PM
kboughton kboughton is offline
kboughton is starting off with a positive reputation.
Injectors??
I have a 2002, 6cyl. with approximately 175 000 KM's..... after the engine starts, the rpm's drop for a split second, almost enough to stall the engine, then they pick up to a normal level. This only happens when the temperature is below -10 degrees C. Also, If I shut the car off and immediatley restart, it starts normally.
Today, after sitting plugged in all day (-40 degrees C.) it fired, then immdeiatley stalled. I then cranked it over again and it started with no problem.
It seems that after it gets the initial surge of fuel it's fine. One member suggested that they are equipped with a cold start injector, maybe my injectors need cleaning?
By the way... this problem seemed to happen after I changed the plugs, maybe it's a coincidence? Thanks for the advise.
  #2 (permalink)
Old 12-17-2008, 01:11 PM
Anyone? Thanks,
  #3 (permalink)
Old 12-17-2008, 06:01 PM
tcesni tcesni is offline
tcesni is new and has a neutral reputation at this point.
Have you ever replaced the IAC?
  #4 (permalink)
Old 12-17-2008, 07:45 PM
I just cleaned the IAC after reading some posts about similiar problems and....it looks like that was it. I'll see if the cleaning will do the trick or if I will need to replace it.
Thanks,
  #5 (permalink)
Old 12-18-2008, 07:40 AM
Its a pretty inexpensive part if you need to replace the IAC.
  #6 (permalink)
Old 12-18-2008, 10:38 PM
I'm not sure about inexpensive, the OEM one is $160.00 cdn. As for an after-market?? Howewver, it was definately the problem because it's back to normal; keeping my fingers crossed.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
