Wheel Bearing/Hub Assembly - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-15-2008, 10:23 PM
Capt.Schenk's Avatar
Capt.Schenk Capt.Schenk is offline
Capt.Schenk is gaining momentum as a positive member of FTE.
Well, I think I'm going to order the cheap set and get whatever else I need locally once the bearings get here. The set I have now are only about two years old and was told they were a "good product" when I got them. I replaced all the ball joints and both hubs two years ago with my Christmas bonus. Looks like I'm doing the same thing again this year. It's always somethin'......
Old 12-15-2008, 10:25 PM
triskit16's Avatar
triskit16 triskit16 is offline
triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.
When did 4 wheel ABS come standard? I know(at least think) on mine I only have real wheel ABS. That might knock a few more off if they specify between 4 wheel ABS and 2 wheel ABS
Old 12-15-2008, 10:29 PM
I'm not sure if I have 4 wheel ABS or not, but am going to check before ordering. I'm sure it's easy to find. I either have a wire harness to my front wheels, or I don't
Old 12-15-2008, 11:33 PM
Lovin7.3's Avatar
Lovin7.3 Lovin7.3 is offline
Lovin7.3 is gaining momentum as a positive member of FTE.Lovin7.3 is gaining momentum as a positive member of FTE.
I just replaced mine. Paid like right at 300 for the Wheel bearing assembly and the 2 gaskets.... 4 studs and 4 nuts. Powerstrokeshop.com
Its a Timken bearing....says MADE IN THE USA! right on the part!!!
Old 12-16-2008, 12:03 AM
FXSTSB FXSTSB is offline
FXSTSB is starting off with a positive reputation.
My quick two cents. I replaced mine yesterday and the lowest price i could fnd locally was 212 at Oreilly auto. That came with an ABS sesor already installed. If you have time to wait for shipping and wanna save a few bucks here are the absolute cheapest i could find. Less than 130 shipped. I am positive that they will not be stamped made in the USA neither was mine for 212 at the local parts store and I am sure they come from the same line over in china. Very easy install took 1.5 hours per side and I did rotors and pads at the same time just because.
eBay Motors: FORD HUB BEARING F250,F350,F450, 4x4 absS-DUTY 515020 (item 190273948427 end time Dec-23-08 12:17:03 PST)=
Old 12-16-2008, 08:57 AM
SGnAZ's Avatar
SGnAZ SGnAZ is offline
SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.
Do these wheel hubs work with the esof system?
Old 12-16-2008, 10:02 AM
They will work with either Hub option. SRW only with 4 wheel ABS. These have a coarse thread on the wheel studs which is what my 2000 F-350 SRW had. I am not sure what trucks came with the fine threaded studs maybe a DRW.
Old 12-16-2008, 10:18 AM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.vettdvr is gaining momentum as a positive member of FTE.
I also bought the Timken from Autozone at $350 + tax and no shipping. But I needed it that day. I am a bit gunshy about using bearings without country of origion being know. There is a lot of technology that goes into making quality steel.
Old 12-16-2008, 03:04 PM
This is what I ended-up buying: Federal-Mogul's Complete Automotive Light Duty Catalog - Part Details
$239 including shipping for two.
Old 12-16-2008, 05:03 PM
If I don't have the autolock hubs, are there any o-rings, seals, gaskets, or anything else that I may need? I'm assuming I will need new studs and nuts, right?
Old 12-16-2008, 05:29 PM
vettdvr's Avatar
Quote:
I would replace the dust seal at the end of the differential tube. I would also use the yellow oring, (the bearing should have this) just to keep the hub cleaner inside and keep water out of the 4wd hub assembly. Even with mechanical hubs!
Be prepared to remove the studs in the old bearings. They are a to remove. Double nut the stud and hold the old bearing in a vice and you can get them out. Don't forget the penetrating oil. I used a wire brush on my drill press to clean out the threads before installation. When you install the studs in the new bearing be sure to bottom out the stud to tighten it.
Old 12-16-2008, 09:24 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Quote:
In 2001 4WABS became standard on Lariat trim levels and above, and standard on all models in 2002
Quote:
I believe the thread pitch on the wheel studs changed when Ford went to the taller wheels in 04.
I've reused the studs twice now. They are plenty big, and no thread locker is used. The o-ring that seals the bearing assembly to the steering knuckle should come with the new hubs.
Quote:
That would make for a long day. What people commonly refer to as the dust seal is actually the outside lip of the axle seal that has broken off. You have to pull the axles out to replace them, which means you would also have to replace the axle seals in the steering knuckle. That's going to add about $130 in parts and at least an extra hour to the job. Plus you'll have to make a seal driver to seat the new outers in the knuckle.
There's a good how to thread with pictures HERE.
  #28
Old 12-16-2008, 10:15 PM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE.cangim is gaining momentum as a positive member of FTE.
OUCH!!!
Just checked the price for bearing assy on a pre 99 at auto zone. Good news is they have it listed, Bad news $587.00 each.
  #29
Old 12-16-2008, 11:05 PM
cookie88's Avatar
You have a Dually?
  #30
Old 12-16-2008, 11:35 PM
cangim's Avatar
Nope, it is a SRW 4x4, rear ABS only. If had known then what I know now, I wouldn't have bought the truck, would have kept looking for a 99.5 or later.
Post up a pic of what your truck looks like TODAY! 73FordF100 1973 - 1979 F-100 & Larger F-Series Trucks 2115 Yesterday 08:50 PM
6.7 modification MotoPro193 6.7L Power Stroke Diesel 18 12-24-2016 11:47 AM
LED light Bar ? big-head Aftermarket Products 9 09-21-2015 01:42 PM
LED light Bar big-head Offroad & 4x4 2 06-20-2015 10:20 PM
What replacement battery? xtrford 1997 - 2003 F150 25 05-29-2008 06:11 PM
Tags
2002, 4x4, assembly, bearing, bearings, f150, f250, f350, fix, ford, hub, replace, ring, sd, studs, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
