Thread pitch on schrader vavle
Darron
If that's what you had in mind I suggest you not do it, at least not as a permanent installation. That was a glycerine filled gauge and it lasted less than 1 round trip to work and back home (46 miles) There are just to many pulses and pressure spikes from the mechanical fuel pump and the gauge self destructed. For a temp gauge to check pressure an extension hose for a grease gun works well to absorb the pulses. For a perm installation you could add some type of restrictive orifice in the fittings or line to cut down on the pulses. A small ball valve in line that's just barely open will do the same thing.
An in line snubber will save the gauge from self destructing.
Pressure Snubbers, models PS-2, PS-4 and PS-8=
http://www.raysnubber.com/cat3.htm
A bit pricey though:
AEM 30-4401 - AEM Digital Display Gauges - summitracing.com
kenpobuck
01-22-2011 07:42 PM
strokin'_tatsch
02-25-2009 11:30 PM
duback66
15
06-29-2006 04:27 PM
