2001 7.3L F350, Service Engine Soon, truck shakes - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 12-23-2008, 06:26 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Glad to hear you're back up and running. Too bad you forgot to put in a plug for FTE on your video.
Did you find any loose bolts on the rockers or injectors? A couple of loose injector bolts really changes the way the truck sounds.
If you're an FTE junkie now, we're glad to have you. Something you might consider is becoming a supporter of this site. Click on any of the supporter badges you see next to a user name, and you can contribute $20 for a supporter badge. This will also remove the ads from the screen and make things easier to read. It's not required, and your welcome to hang around for free, but the contributions help keep this site going. And I'm guessing a mechanic would have probably charged you more than the 50 cents you've got invested in the repair.
  #47
Old 12-23-2008, 06:33 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
X2
  #48
Old 12-27-2008, 07:03 PM
99350Ron 99350Ron is offline
99350Ron is starting off with a positive reputation.
Thank you very much. I just finished the passenger side with the quarter shim. Truck is back and running normally. I will do the driver's side on another day to ensure no problem on that side. I know of two other good friends whos trucks had the same symptoms. Both went to mechanics. One got new glow plugs and the other got at least one new injector, possibly more. Hopefully they were'nt sold something they didn't need, but I am sure glad I did this check and fix before taking it somewhere. Thanks again...Ron.
  #49
Old 12-27-2008, 10:29 PM
dahr85 dahr85 is offline
dahr85 is starting off with a positive reputation.
Hey Chris,
Check out the YouTube video now:
YouTube - 2001 F350 7.3L Turbo Diesel, UVCH
I've added a quick plug for FTE at 1:35. I can't believe I forgot to mention it the first time. My bad.
Thanks again.
Darren
  #50
Old 12-28-2008, 08:49 AM
F350-6's Avatar
Quote:
There's no telling how much people have spent at repair shops fixing some of the items we see here. You might want to encourage your friends to join FTE so they can learn about this type of stuff.
Quote:
Originally Posted by dahr85 View Post
Hey Chris,
Thanks again.
Darren
Nice job with the FTE plug.
  #51
Old 12-28-2008, 12:26 PM
DieselBeast01's Avatar
DieselBeast01 DieselBeast01 is offline
DieselBeast01 is gaining momentum as a positive member of FTE.
I have to subscribe to this one. I'm gonna be pulling some valve covers soon to check all of this. Nice job on the explanation Chris and great job on the video post Darren.
  #52
Old 12-28-2008, 03:20 PM
Scruffy's Avatar
Scruffy Scruffy is offline
Scruffy is starting off with a positive reputation.
Chris and Darren, great job on the instructions and video! Reps sent to both. I took mine to the dealer not too long after buying my truck. I think it was on a recall as I recall and haven't had a problem since, but will keep this in mind if I have any problems of the like. Well worth being a supporter for a few hours of time and 50 cents for a repair!
  #53
Old 01-13-2009, 09:33 PM
7.3johnsonville's Avatar
7.3johnsonville 7.3johnsonville is offline
7.3johnsonville is starting off with a positive reputation.
Thanks goes to the guys who put effort into the diagnostics and repair of our trucks, i have learned more about my truck n the past few days trying to find my problem than many colledge courses could teach me about deisels in a year. this thread and a few other HELPED out ALOT. hope i can be of some help to some one one day now that i know the mechanics of a diesel. Just another Thanks!
:-2XX
  #54
Old 01-14-2009, 07:06 AM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
And how many repair shops have used this information to fix vehicles!
  #55
Old 01-14-2009, 07:32 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
I missed this thread the first time -- great job, Chris!!
What gets me is the ~$100 VC gasket!! What a joke!! Most of the time, they don't need replaced...
  #56
Old 01-18-2009, 03:23 PM
jeepdude jeepdude is offline
jeepdude is starting off with a positive reputation.
Great post... I think this is a solution to my problem also, having the intermitent ses light also. I can push down on the connector on the driver side valve cover while the truck is running and change the pitch of the truck considerably. Passenger side doesn't change when I mess with it.
  #57
Old 01-23-2009, 01:46 PM
Worked for me... only took about an hour to do the driver's side
thanks for the helpful post
mike in indiana
  #58
Old 02-22-2009, 04:01 PM
Bulloxor Bulloxor is offline
Bulloxor is starting off with a positive reputation.
did the test and found evething good on the passenger side but the drivers side showed one injector reading open no reading checked multiple times just to make sure same thing what now?
  #59
Old 02-22-2009, 04:09 PM
F350-6's Avatar
Welcome to FTE Bulloxor. Tell us what symptoms your truck is experiencing. With this thread, I'm guessing it's running very rough? I'd say you're next step is to pull the valve cover. At this point, you can check the wiring to be on the safe side. Also check where the wire plugs into the injector. A slight miss with the CEL could indicate a bad injector, a really rough running truck could indicate a bad injector solenoid which can take down the entire bank.
A simple test is after you get the valve cover off, unplug the suspect injector and see if it changes how the truck runs. You can also start the truck with the everything still plugged in and observe the oil discharge from each injector. If the open injector is not spitting any oil, that means it's not firing.
  #60
Old 02-22-2009, 04:12 PM
how do i know which injector is the bad one, i know which pin read bad how do i follow thru
any help please? Austman14 1999 - 2003 7.3L Power Stroke Diesel 3 11-09-2014 04:41 PM
7.3l diesel 2001, shakes at 45-60 mph SES light on. entropyjones 1999 - 2003 7.3L Power Stroke Diesel 34 10-06-2014 03:03 PM
truck is running rough and shaking, not running on all cylinders? and shifting hard 4x4countryboy 1999 - 2003 7.3L Power Stroke Diesel 22 10-13-2011 08:58 PM
2001 F350 4x4 is running very rough, shaking and shifting hard 4x4countryboy 1999 - 2003 7.3L Power Stroke Diesel 10 10-11-2011 10:20 PM
hard to start ...sometimes mike slattery 1999 - 2003 7.3L Power Stroke Diesel 7 11-19-2006 10:00 PM
Tags
2000, 2001, 73, engine, f150, f350, ford, light, loose, loses, power, service, shakes, speed, start, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
