2001 7.3L F350, Service Engine Soon, truck shakes - Page 19 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #271
Old 08-15-2014, 02:57 PM
NorthernWild NorthernWild is offline
NorthernWild is starting off with a positive reputation.
Sorry VROD, I haven't taken off the valve covers at this point, so I'm not sure what that measurement is, though I'm curious what you'd want it for.
I'm starting to doubt my problem is the UVCH, so I'm starting a new thread here: http://www.ford-trucks.com/forums/13...l#post14585477. If I find out it was the UVCH after all, I'll post back here.
  #272
Old 08-15-2014, 03:33 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Quote:
Originally Posted by VROD View Post
Hello can someone take a measurement from the end of the plug that loosens up to the valve cover gasket thanks
Uh? I have an old UVCH in my "box of shame". Do you need a measurement from that?
  #273
Old 08-15-2014, 07:35 PM
VROD's Avatar
VROD VROD is offline
VROD is starting off with a positive reputation.
Quote:
yes from the edge of the valve cover to where it unplugs if you can thanks
  #274
Old 08-16-2014, 03:13 AM
My intermittent, but worse when hot problem turned out to be cylinder 6 injector wire shorting to valve cover where wires exit 42-pin connector and tend to rub against valve cover. IDM code was P0276. Details in this thread: http://www.ford-trucks.com/forums/13...l#post14586703.
  #275
Old 08-28-2014, 09:15 PM
jackoney jackoney is offline
jackoney is starting off with a positive reputation.
no resistance on injector
Hi! great thread! My engine started running rough, I check ohms like was suggested, I had no resistance on #3 on drivers side, so took apart, but my problem was the clip that holds the lead on the injector it self came lose, don't know how that happened, but it did. Put it back together and now purrs like a kitten! hope this helps someone else! Thanks guys!
  #276
Old 10-09-2014, 11:13 PM
Rdy2offrd88 Rdy2offrd88 is offline
Rdy2offrd88 is starting off with a positive reputation.
So I just pulled my drivers side valve cover tonight and my connection was loose so I did the 50 cent mod and put everything back together and cranked it up and everything was good except now my HPOP press gauge isn't reading anything at all?? Also it sounds like my afe intake now has more of a rumble to it alsmost like I can hear inside the motor from my air filter. I don't remember it sounding like this before. Any ideas?
  #277
Old 10-10-2014, 06:58 AM
Tugly's Avatar
Maybe you missed the CCV hose... it's been known to happen (unless I'm the only one)
  #278
Old 10-10-2014, 07:45 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
How does your HPOP guage get it's reading?
  #279
Old 11-02-2016, 02:19 PM
TerranE's Avatar
TerranE TerranE is offline
TerranE is starting off with a positive reputation.
Quote:
Originally Posted by F350-6 View Post
Welcome to FTE Darren. Most of the generic (read inexpensive) code readers will not work on our engines. I'd be willing to guess if you could read the code that is in there it would be a P1316 code. The common cause for what you're describing is a loose plug on the UVCH (under valve cover harness)
Here's what the problem looks like
Now the trick is to figure out which valve cover you need to remove to plug this thing back in. Since you don't have a good scanner that can run things like a buzz test, the next best option is to grab a multi-meter and set it to read ohms. Located on the inboard side of each valve cover you will see some wires leading to a plug connector. This is a flat 9 pin connector that you will need to unplug to expose the pins inside.
The 9-pin plug is wired as follows:
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
The injectors fire with a 115VDC signal from the IDM. Do Not pierce the wires to test.
Test between "I" and "C" to test the injectors, should be less than 5.0 Ohms.
To check glow plugs Test between "G" and battery ground. Should be between 0.6 and 2.0 Ohms
If you find readings outside these numbers, pull that valve cover and check for the loose connector.
We also have a 7.3 diesel specific section located a little further down the main forum listing page. We'll see if we can't get your thread moved down there so you get more input on this from other folks that have the same motor.
Testing the injectors "I" and "C", I had a reading of around 7.2 on a couple of contacts. After tightening the inside connector, the reading was still 5.2 on one connector. Still not under 5 ohms. The other connectors had correct readings. Should I spend the quarter and put it back together or should I investigate it further?
I apologize if this is already covered. I thank you all in advance and I thank all who contributed to this thread already. It has been a big help. Terran
  #280
Old 11-02-2016, 07:59 PM
F350-6's Avatar
Without knowing the symptoms that got you to this point, we can't give you an answer. My first suggestion would be to start the truck up (valve covers off is ok) and see how that affects whatever issue you might be having.
Starting a new thread with all your specific symptoms and steps taken thus far would be even better.
  #281
Old 11-02-2016, 10:19 PM
TerranE's Avatar
I have the same truck as the OP with pretty much the same symptoms. Service light, low power, stalls.
I think that you've pretty much provided most of the answers I needed already.
I've tested the ohms at the under valve cover connections and have found them out of range.
I've already sprung for new Ford gaskets, wire harnesses, Motorcraft glow plugs, along with o rings to do the crankcase vent mod.
I think I have my bases covered, thanks to you. If I have any troubles, I'll start a new thread. Thank you.
  #282
Old 01-12-2017, 07:16 PM
wildlifer's Avatar
wildlifer wildlifer is offline
wildlifer is gaining momentum as a positive member of FTE.
I have not posted here for a few years, but still my go-to for information -- thank you for the excellent details, particularly at the beginning of this thread, where I landed when I pulled my truck out of work this evening & light popped on, started stuttering & losing power & I worried I'd lost an injector or something. I will confer with my diesel guy tomorrow (NOT a dealer, a very very gifted neighbour; darn job keeps me too buried & exhausted to take things apart in the yard much anymore), but I am grateful to this thread for giving me hope that maybe it doesn't have to be a $$$$$ problem.
any help please? Austman14 1999 - 2003 7.3L Power Stroke Diesel 3 11-09-2014 05:41 PM
7.3l diesel 2001, shakes at 45-60 mph SES light on. entropyjones 1999 - 2003 7.3L Power Stroke Diesel 34 10-06-2014 04:03 PM
Sputtering and no power?! Ole Smokey7 1999 - 2003 7.3L Power Stroke Diesel 9 04-11-2013 09:16 PM
truck is running rough and shaking, not running on all cylinders? and shifting hard 4x4countryboy 1999 - 2003 7.3L Power Stroke Diesel 22 10-13-2011 09:58 PM
2001 F350 4x4 is running very rough, shaking and shifting hard 4x4countryboy 1999 - 2003 7.3L Power Stroke Diesel 10 10-11-2011 11:20 PM
Tags
2000, 2001, 73, engine, f150, f350, ford, light, loose, loses, power, service, shakes, speed, start, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
