I'm looking to replace my stock tires after installing a 2" AS and was looking at tires in the size 275/70/18 and was wondering if anyone on here was running them and if you had pictures. Thanks in advance.
You should probably go with a 285/70/18. The ones you mentioned are going to be the same width, and just a hair taller. (in case you DIDN'T already know that) Might look weird.
Who makes a 285/70/18? Never seen one, just curious...
he could fit the 275/70's without a leveling kit also. Isn't that about a 1/2" taller? 70% of 275mm, or 5% more? If I'm going taller, I'm going wider also.
when you look at the specs on the tires, it looks like with most of them you gain around an inch to and inch and a quarter in height and very minimal around .1-.25 in width by going with a 275/70/18 instead of a 275/65/18
