How many quarts of oil for the 5.0 - Ford Truck Enthusiasts Forums
Old 12-14-2008, 03:39 PM
truknut1972 truknut1972 is offline
truknut1972 is starting off with a positive reputation.
I have a 92 F-150 with the 5.0. I changed the oil the other day, I put 5 qts. and the dipstick and it still shows that I'm still a qt. low. I looked at the owners manual and it said it takes 5 qts. So how many should I put in it? Thanks, Jeff.
Old 12-14-2008, 04:58 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
6 with filter.
Old 12-14-2008, 06:32 PM
mstngmikegt's Avatar
mstngmikegt mstngmikegt is offline
mstngmikegt is starting off with a positive reputation.
Quote:
Originally Posted by quicklook2 View Post
6 with filter.
What he said. My 95 takes 6 (with filter). Manual for my 95 confirms this....says 5 or 6 (with a filter change). Side thought...who the hell changes oil and doesn't change the filter?!?!?
Old 12-14-2008, 06:55 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
[quote=mstngmikegt;6883697]What he said. My 95 takes 6 (with filter). Manual for my 95 confirms this....says 5 or 6 (with a filter change). Side thought...who the hell changes oil and doesn't change the filter?!?!?[/quote
One can only wonder.......
Tim
Old 12-14-2008, 07:18 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Quote:
A dumba$$!!!!!!!!!!!!!!!!!!!!!!
Old 12-14-2008, 08:01 PM
05chop 05chop is offline
05chop is starting off with a positive reputation.
If the pan holds 5 quarts then you will have to remark the dip stick.This is a stock oil pan correct?
Old 12-15-2008, 08:14 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Quote:
6 with filter.
Right on the money and straight out of the owner's manual. Best I remember, all the gasoline engines from 87-96 require six quarts of oil to refill after an oil and filter change.
Old 12-15-2008, 08:28 PM
justin_brandstein's Avatar
justin_brandstein justin_brandstein is offline
justin_brandstein is starting off with a positive reputation.
Acctually alot of mechanics who use only synthetic do it every other... or if the oil change is because of droping a pan or something like that.
Old 12-15-2008, 08:36 PM
EPNCSU2006's Avatar
Seems like with synthetic oil and its extended drain capabilities, the filter would be change more often than the oil, not the other way around...
Old 12-15-2008, 11:28 PM
95F350XL 95F350XL is offline
95F350XL has a good reputation on FTE.95F350XL has a good reputation on FTE.95F350XL has a good reputation on FTE.
At our shop we change the filter any time we have to dump the oil, its only like a few bucks and you might as well. With syn and the longer oil changes id have to say ud better change it. My boss wants 4k with the semi-syn that we have in a huge tank, and 5K on full-syn and diesel oil changes. I do 3K on what we use in most cars caus thats just me, and ill do like 4 on the syn and diesel just caus thats also me. Id do 3 on the diesel if i could caus that stuff gets so nasty, but with the Fords takin 15 qt, and the chevs/dodge taking 9-12 and at 89.99 we cant do it like that lol.
Old 12-16-2008, 12:44 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
I tend to do 7 to 10k miles on the full syn. I had a girlfriend once who's dad only changed the filter every other oil change. Thought he was saving money. It worked for them her car had well over 250k miles on when it finally died.
How many qts. of oil does the 6.7 hold ?? Montana Hoss 6.7L Power Stroke Diesel 45 09-24-2016 12:32 PM
2015 Ford F-150 5.0 Oil Capacity? mantta 2015+ F150 0 03-28-2015 06:08 PM
Oil Capacity for my truck pickenspolitics 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-09-2015 09:48 PM
312 Y-block grnboger 1961 - 1966 F-100 & Larger F-Series Trucks 16 01-07-2014 06:51 PM
2008 trans pan upgrade-how many qts of fluid? Money-Pit 6.0L Power Stroke Diesel 3 11-17-2013 06:45 PM
Tags
2007, 50, engine, ford, number, oil, quarts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
