5.4 Oil ports
5.4 Oil ports
Hello, I posted this in the f-150 but I have had no responses. I want to install a by-pass filter on my 5.4. I know my PSD had two ports with plugs in them above the oil filter. You just remove the plugs and connect the filter and you are ready to go. Anyone know of some ports on the 5.4 that are the preasure side of the oil pump to connect the by-pass filter? Thanks
On the 2V engines,there is a 1/8" NPT port at the passenger side front corner of the cylinder head,and the driver's rear corner in the same location. These are almost at the dead end of the oiling path,right before the timing chain tensioners. They're pretty easy to get to-I've seen the passenger side port used for lube feed on Vortech Supercharger installs. I'm not sure if the 3V has something in that same location-I've never looked for it.
JL
JL
JL
JL
I took pictures through the wheel wells of my 5.4L Superduty. This is the pass side,
This is the drivers side,
The lower plug on the driverside looks identical to the one on the pass side. Is there any reason I couldn't use this one for oil pressure? Or am I looking at the wrong place?
JL
I've read this topic, and also did some searching. I am planning to install an accumulator type preoiler to a 99 5.4, installed in an Econoline passenger van.
I tested the system using the 3/8 NPT port on the passenger side aft end of the head.
While I did get a normal oil pressure indication on the gauge prior to cranking the engine (key on, accumulator active), I didn't notice if the oil indicator light went out.
If this engine does have oil galley restrictors, is there a better point to apply pre oiler pressure. I would really like the entire engine pressurized, but could deal with just getting pressure to the main and rod bearings.
FWIW, I was planning to add a "T" in the accumulator hose to monitor oil pressure, but a previous post has me questioning that.
Also, where could I expect to find the OEM oil pressure sender, I believe it on the head, and that was one reason I opted for the 3/8 thread oil port.
Any comments or ideas.
Thanks
PK
Thanks
PK
2500ak
19
10-30-2013 01:10 PM
Yahiko
09-26-2012 12:03 PM
nlemerise
18
02-01-2008 07:57 PM
