To the Japanese, the term "jap" is as offensive to them as the N word is to African-Americans.
I'm glad someone finally straightened that out because was beginning to get a little miffed about the abbreviations. This is a heated yet friendly site, no need to make it hateful.
Tim
__________________ SCPO United States Coast Guard Retired '04 Expedition XLT 4x2 '99 Taurus Wagon SE 24V '88 F-150 4x4 XLT Lariat 5.8L 5Spd
Rights of Passage: CPO Initiation, Submarine Qualified (SS), Golden Shellback, Blue Nose, Order of the Ditch
African-Americans. What is that? Those people do not exist. Either you are an American or you are not. You cannot be both unless you have dual citizen ship. Then it still would not apply. You would need the country there like African-Egytian.
The above comment is from an American and Proud to Be!
__________________
Paul West Virginia Chapter
2001 F-250 7.3 Powerstroke Super Duty XLT Extended Cab 4X4 6 Speed 3:73
Goodyear Wrangler 305/70R16 ATS Tires
Banks Intercooler, tubes and 1999 Turbo Wheel
Steel HPX and CCV Mod
Bully Dog 4" Exhaust and AIS II Air Filter FTE TEAM MEMBER of 53449
Member "Boy you ain't right club#7"
According to US law, dual citizenship applies till one reaches 21 years of age, then the person has the right to claim the US or whatever country they were born in for their citizenship.
Since you don't wish to use the term African-American inre to the N word, what term would you care to use?
Previous to the term African-American, the accepted term was Black, before that it was Negro, before that there were several derogatory terms I'm not going to type here.
__________________ Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
I said AMERICAN, nothing else is correct!
__________________
First it was the Honda Prius and now Toyota uses cork gaskets.
I'm thinking some of those books you use may have a few mistakes in 'em. Tim
I have no clue what Honda and Toyota use for gaskets, I have no parts catalogs for them (don't want any either) and I've never made an reference to them, regardless.
Outside of the Brits, only Studebaker, as far as I know, used cork for valve cover and oil pan gaskets from day one thru 1966.
Those Studie cork gaskets leaked like sieves as they did on every British pile I've owned (two 1950's Jags, an '52 MG-TD, two 1960's Rollers and a '62 Bentley, which I still own and is leaking oil as I type!).
I also have a 1963 Studebaker R2 Super Hawk, but the gaskets have been replaced by the neoprene type.
I'm referring to post #74 where you stated Honda is cutting back production on the Prius.
I guess you could have said they cut production to 0 since Honda doesn't make the Prius.
As far as not making reference to Toyota/gaskets; you most certainly did considering the current Lotus uses a Toyota drivetrain.
__________________
I'm referring to post #74 where you stated Honda is cutting back production on the Prius. I guess you could have said they cut production to 0 since Honda doesn't make the Prius. As far as not making reference to Toyota/gaskets; you most certainly did considering the current Lotus uses a Toyota drivetrain. Maybe some research before you post?
OK..you got me on the Prius, but...
I could care less what Lotus uses for a drivetrain, and considering how many 1,000's of Ford part numbers I've typed here, I've done more research than anyone on FTE.
Could care less? Or could NOT care less?
Just thought that you commenting on how the "The cork engine/trans gaskets that leak like sieves." on the Lotus meant you knew something about the current ones since you added your vast knowledge to the subject.
I mean if anyone else makes a mistake, you do make sure to correct them; thought maybe you'd like the same courtesy.
Tim
My apologies, I was unaware the Lotus used a Toyota powertrain, but that was not always the case.
If you've ever owned British cars, you come to expect the Lucas Electricals will be NFG, the powertrains to leak like sieves, and the power brakes boosters are another thing that usually needs repairing.
Then there's the body work. If you are interested in buying one a these piles, and it has RHD and is painted white...stay away.
Back in the 1980's, 1000's of British Rollers and Bentleys were imported here, many were rusted out. What the crooked dealers did in the UK to hide that fact was to use chicken wire and Plaster of Paris instead of bondo, then painted the cars white.
Take it for a drive...hit a coupla bumps in the road, the lower half of the front/rear fenders, the lower section of the doors, the front and rear valance panels, part of the decklid could and did fall off.
Ha Ha, Ken, I don't need to lighten up, both of my last 2 post weren't serious. You answered to them like thet were serious, I guess I didn't put enough ha ha in there.
__________________
2009 FORD RANGER fx4 off/road, 5-speed manual, torson diff and rancho's!
I also totaly admit british cars along with german, italian, scandinavian, etc. cars suck. I have never worked on a worse car than the VW bug. That right there is the worst engineering I have ever seen out of any car.
I also have been a ford fan all my life and have owned many ford cars and trucks. I currently have a 96 F250 in my sig. a 00 lincoln LS in my avatar, 77 T-bird, 68 mustang coupe, and a 89 F250. They are all great but they have their problems.
I also own hondas though. A 02 odessey mini van, 88 CRX, and 91 CRX. I have owned many many other hondas as well and I must say they hold up and break down a LOT less than any ford, saab, chevy, dodge, or toyota that I or my wife have owned. And these are high mileage hondas too. Both crx's have over 225,000 miles and still going strong without hardly any problems ever! I say hardly because I am counting battery replacement and the occasional brake change but that is seriously it. The 02 odessey hasn't had a wrench touched to it yet besides for the oil pan drain plug and has 115,000 miles on the clock. My wifes last honda civic with 235,000 miles ran and drove perfectly. I didn't even change the oil on it, just added a quart about every 2 months lol. I had to replace the rear brakes once.
People always ask me if I like my hondas and why I keep buying hondas. The short answer is yes and the whole shpeel but than I also tell them to ask people they see with hondas and see if they can find someone to say they don't like their honda. My dad (diehard ford man) has yet to find one person to say they don't like their honda.
