97 ranger gem system?
Old 12-13-2008, 04:34 PM
ttocs388's Avatar
ttocs388
ttocs388 is offline
I have a 97 ranger that I am the original owner of. Over the past few years I have started to have intermitten problems with my dome light staying on. I could not seem to figure out if it was related to the drivers side or passenger side door trigger nor if it had to do with weather. I figured out when it did this that I could temporarily remove a relay in the passenger side kick panel to turn it off and for some reason if I left it out for a day or so then it would be good for another month or so.
Now a month ago I started having problems with it staying on more constantly and I just got use to having the relay out and not having a dome light. For the last two weeks if I let the truck sit more then a day the battery dies on me. Today I hooked up an amp meter and started pulling fuses and isolated it to fuse #25, the GEM system fuse(with relay #1 still removed). When I pulled this fuse I could hear another relay in the dash(next to the radio) click. With the fuse in place and relay #1 still removed my current draw would go from .5A to 0 when I pulled this relay. I had a few extra relays and tried them but nothing worked.
Old 12-13-2008, 06:31 PM
drb1956's Avatar
drb1956
drb1956 is offline
Dome Light
The biggest problem with the dome light staying on is a switch in the door latch that sticks on...try spraying WD-40 with a spray tube into the latch in the door-that should do the trick. Most Ranger owners have had this problem one time or another....a few other Ranger owners can chime in on this, unless you really do have an electrical problem that some of the guys can help out with.... Just my two-cents.
Old 12-14-2008, 09:51 AM
drb1956's Avatar
drb1956
drb1956 is offline
Anybody get a gander at this problem??????
Old 12-14-2008, 10:31 AM
ttocs388's Avatar
ttocs388
ttocs388 is offline
I will try the wd40 but if there is any other advise it would be great...
Old 12-14-2008, 05:40 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
As mentioned, 99% of the time the problem can be remedied by spraying wd40 on the switch mechanism, which frees up the switch. Spray liberally and work the door handle while spraying. If that doesn't work then the switch probably bad and has to be replaced.
gmacthree
Electrical Systems/Wiring
08-30-2016 07:48 PM
ejj44
1997 - 2003 F150
15
03-16-2010 07:19 PM
m_menosky
11-29-2009 09:21 AM
meader1977
10-08-2009 12:57 PM
Bob97F350
19
04-13-2009 05:10 AM
Quick Reply: 97 ranger gem system?
