high Idle? 1994 ford f350
Old 12-13-2008, 03:16 PM
94F350IDI's Avatar
94F350IDI
94F350IDI is offline
hi, how would i go about setting a high idle setting on my 1994 ford f350 up?
Old 12-13-2008, 08:49 PM
dakotajeep's Avatar
dakotajeep
dakotajeep is offline
Yeah, it seems that mine used to have a high idle but this year I havent had it.....or maybe its just me....
Old 12-13-2008, 10:00 PM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
At Cold Idle Solenoid:
1. Place transmission in NEUTRAL or PARK.
2. Start engine and bring up to normal operating temperature.
3. Disconnect fast idle solenoid from wiring harness.
4. Apply battery voltage to solenoid to activate it.
5. Rev engine momentarily to set solenoid to activate it.
6. Check fast idle speed setting. Fast idle rpm should be 825 ± 25. Adjust to specification by turning solenoid plunger in or out (Figure 11).
7. Rev engine momentarily and check fast idle rpm. Adjust as necessary.
8. Remove battery voltage from solenoid connector and connect to wiring harness.
Old 12-14-2008, 09:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
Inspect this wire, make sure it is still on the temp switch.
That switch controlls the timing advance and fast idle.
The wire is rather easy to knock off when you are working on glow plugs, return lines, IP wiring or the alternator.
tbugher62
10-29-2014 12:38 AM
f350ranchand
11-11-2012 07:26 PM
Scott Stewart
11-02-2011 05:37 PM
94F15094
11-01-2010 02:52 PM
Quick Reply: high Idle? 1994 ford f350
