open glove box take it out by pushing in the tabs....then there is a black plate with 4 or 5 screws in it take them out u will see it....go under hood unhook hoses pull out through the glovebox and reverse to put back in
i will add: mark hoses, drain gallon or so of coolant, put towel inside cab or plastic when pulling core out, clean out debris and make sure flapper door is working inside heater box.
You might find a couple of vacum lines and or a cable across the cover for the heater core. Just get them loose and you don't have to unhook them. Might have to twist and turn the heater core to get it out, but it will come out. The blend door is in the lower left corner under the cover. The entire operation takes less than 1/2
hour
Not hard at all.
Good luck Frank
