Data Logging (examples)
I am rather new to this site. Is there an area on here that I am not seeing where people can post screen shots of data logs? It would be of tremendous help to me in troubleshooting my truck. I really don't know where some of the numbers should be to know if they don't look right... If there is no such place maybe somebody could hook me up with some good running logs from a
99.5 PSD 6 Speed.
I am having a lot of trouble fixing my rig, it runs so so, but lacks power at high RPMs and especially under load. It will not pull any codes and does not have a check engine light on.
Thanks for the help... Jason
99.5 PSD 6 Speed.
on
By asking for data logs you're asking a very vague question. Data log what items? There are dozens of parameters which can be data logged. Then, someone else's logs are meanless compared to your truck unless the conditions of the logging are similar (temp, load, truck configuration). What parameters exactly, are you wanting logged, and why? Are you running a chip or tuner? If so, do you have a boost and EGT guage? How is boost under the conditions where you're having problems? Have you checked to see if high EGT temps have damaged the vanes on the turbo?
bobbyrjw
07-29-2011 09:07 PM
MudBugn
03-30-2006 11:35 AM
