Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-12-2008, 08:03 AM
sundy58's Avatar
sundy58 sundy58 is offline
sundy58 is starting off with a positive reputation.
Waste coffee grounds offer new source of biodiesel fuel
FYI
IMAGE: Waste coffee grounds can provide a cheap, abundant source of biodiesel fuel (shown), researchers say.
Click here for more information.
Researchers in Nevada are reporting that waste coffee grounds can provide a cheap, abundant, and environmentally friendly source of biodiesel fuel for powering cars and trucks. Their study has been published online in the American Chemical Society's (ACS) Journal of Agricultural and Food Chemistry, a bi-weekly publication.
In the new study, Mano Misra, Susanta Mohapatra, and Narasimharao Kondamudi note that the major barrier to wider use of biodiesel fuel is lack of a low-cost, high quality source, or feedstock, for producing that new energy source. Spent coffee grounds contain between 11 and 20 percent oil by weight. That's about as much as traditional biodiesel feedstocks such as rapeseed, palm, and soybean oil.
Growers produce more than 16 billion pounds of coffee around the world each year. The used or "spent" grounds remaining from production of espresso, cappuccino, and plain old-fashioned cups of java, often wind up in the trash or find use as soil conditioner. The scientists estimated, however, that spent coffee grounds can potentially add 340 million gallons of biodiesel to the world's fuel supply.
To verify it, the scientists collected spent coffee grounds from a multinational coffeehouse chain and separated the oil. They then used an inexpensive process to convert 100 percent of the oil into biodiesel.
The resulting coffee-based fuel — which actually smells like java — had a major advantage in being more stable than traditional biodiesel due to coffee's high antioxidant content, the researchers say. Solids left over from the conversion can be converted to ethanol or used as compost, the report notes. The scientists estimate that the process could make a profit of more than $8 million a year in the U.S. alone. They plan to develop a small pilot plant to produce and test the experimental fuel within the next six to eight months.
Biodiesel is a growing market. Estimates suggest that annual global production of biodiesel will hit the 3 billion gallon mark by 2010. The fuel can be made from soybean oil, palm oil, peanut oil, and other vegetable oils; animal fat; and even cooking oil recycled from restaurant French fry makers. Biodiesel also can be added to regular diesel fuel. It also can be a stand-alone fuel, used by itself as an alternative fuel for diesel engines.
*The research in this press release is from a copyrighted publication, and stories must credit the journal by name or the American Chemical Society.
News media may obtain a full text of this report ("Spent Coffee Grounds as a Versatile Source of Green Energy") in ACS' Journal of Agricultural and Food Chemistry by contacting Michael Bernstein.
Contact:
Mano Misra, Ph.D.
Professor
Director, Center of Materials Reliability
University of Nevada-Reno
Reno, Nevada 89557-0042
Phone: 775-784-1603
Fax: 775-784-4949
E-mail: misra@unr.edu
The American Chemical Society—the world's largest scientific society—is a nonprofit organization chartered by the U.S. Congress and a global leader in providing access to chemistry-related research through its multiple databases, peer-reviewed journals and scientific conferences. Its main offices are in Washington, D.C., and Columbus, Ohio. The ACS Publications Division currently publishes 35 leading peer-reviewed journals in the chemical and related sciences, including the flagship Journal of the American Chemical Society, as well as Chemical & Engineering News, the Society's weekly news magazine.
__________________
1995 F350 DRW Superchip 1705 NAPA Filter mod.Welldesigned GVWR
  #2 (permalink)
Old 12-12-2008, 05:39 PM
zhilton's Avatar
zhilton zhilton is offline
2004 Ford F-250
My Garage
zhilton is starting off with a positive reputation.
Coffee grounds you say? Interesting, now we'll have another air pollution coming out of the tail pipe. It used to be just the smell of Chinesse, Fries or fried chicken...now coffee.
__________________
1972 Ranchero GT 351C (Engine code "Q")
2001 Explorer XLT 2WD
2004 F250 PSD CC Lariat 2WD "Pavement Princess" (bone stock...for now)
  #3 (permalink)
Old 12-12-2008, 06:11 PM
jmaskew's Avatar
jmaskew jmaskew is offline
jmaskew is gaining momentum as a positive member of FTE. jmaskew is gaining momentum as a positive member of FTE.
Very interesting article. I can see it now.... our trucks may smell like Vanilla Nut Bean! Hey, what ever works!
__________________
^Camping at ZION NP, Utah^
Jonathan
2004 F250 PSD SB King Ranch 4x4:Build Date: 01/23/2004
Dieselsite Coolant Bypass Filter, High Idle Mod
Fumoto Oil Drain Valve, Harpoon Mod, Zoodad
Isspro 40 PSI Boost, Water Temp, Oil Temp and Trans Temp
  #4 (permalink)
Old 12-13-2008, 10:48 AM
SD26's Avatar
SD26 SD26 is offline
SD26 is starting off with a positive reputation.
Interesting.
So, are the used grounds just pressed, water removed, then the oil is used? Hmmmm....
__________________
SD
2003 Excursion Limited 4WD 7.3PSD - Prodigy brake controller, DP Tuner-60t/80e/AIC/exhaust brake, BG drive line fluids, Timbrin rear springs, 203* thermostat, Evans coolant, coolant filter, Ford Transmission Cure
2001 Focus ZTS, SVT suspension, Evans coolant, K&N air filter
2007 Buell XB12R road racer
  #5 (permalink)
Old 12-13-2008, 07:09 PM
zhilton's Avatar
2004 Ford F-250
My Garage
Quote:
Originally Posted by SD26 View Post
Interesting.
That was the impression I got from reading the article. Like everything else related to alternative sources for diesel fuel...I'd love to read more about this very subject.
__________________
  #6 (permalink)
Old 12-25-2008, 04:26 PM
TchTchr TchTchr is offline
TchTchr is starting off with a positive reputation.
And here I've been putting them on the garden. It's always fun to hear of new ways to power our vehicles.
__________________
Brad
Southern Indiana
Vehicles:
2001 F-250 CC - Vegistroke, many performance goodies - scary fast off the line
1981 Mercedes 300TDT - greasecar conversion, what a highway cruiser!
1963 Chevy II - bone stock - restored (by me), my grandpa bought new, my first car (1980) - my baby
  #7 (permalink)
Old 01-17-2009, 07:45 AM
Lvcrprts Lvcrprts is offline
Lvcrprts is starting off with a positive reputation.
Does that mean our trucks will smell like burnt coffee grounds or is that just when we fart?? LOL
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
