Set up for winter B100?
So here it is winter time. I need to run B50 -B80 so the fuel will not gel. I was thinking it would be really nice to be able to run B90 or better yet B100. So I am trying to see if this is possible without major mods. The one problem that I see is the plastic fuel tank. All the heaters for fuel tanks say not for use on plastic tanks. So has anyone found a heater that will work on our plastic tanks? I also was thinking maybe a fuel filter heater. Has anyone used one? I am looking for any suggestions.
That's what I thought. It would be too much time and money to have a two tank heated system like a vegistroke. I live in a semi-mild climate. It gets down to the high 20's low 30's during the cold spells and warms up during the day. So I was thinking about a mild set-up to heat the main parts of the fuel system. I have a block heater and that helps when it gets really cold. I usually fill up weekly and it is a pain in the*** in the winter. I fill up with some dino and then drive across the county to fill up with bio. It would be so much easier to just fill up with bio and not deal with a gas station.
