Navi AWD question
It'll probably try and engage the front axle, hence why it's all wheel drive.
I believe you can pull a fuse or something that basically pull power to the system. My answer should only be a quick response and something for you to search the forums for.
Don't go pulling the fuse because of my response, <-- my disclaimer.
Call up your Ford/Lincoln dealership too and ask them. Maybe they have an idea.
-rockstate
-rockstate
Your front tires should not engage on a dyno. They only lock in if the system sences some slipping. Its not an all time AWD system. Unless your is totally different than mine.
I copy & paisted this for you.
The only available transmission, regardless of engine, is an automatic 4-speed, but you can order the Expedition with either 2wd or awd. Ford's Control Trac has a dashboard switch that allows you to select 2wd, awd, 4wd High or 4wd Low. In the awd setting, Control Trac selects 2wd for normal driving, but automatically engages 4wd when it senses the rear wheels slipping. This makes for better traction on wet, loose or icy surfaces. Four-wheel antilock disc brakes, dual airbags and an antitheft system are standard. A locking center differential and a skidplate are available optionally, as are front/rear air conditioning plus two types of air suspension systems (one for 2wd and one for 4wd).
Um sorry you two but I have to point out the obvious. If the rear wheels are on the dyno rollers and are turning, while the front wheels are on the floor and are not turning, to the A4WD system this will appear to be rear wheel spin. The system will engage the front axle and the vehicle will lurch forward.
I have to do smog every year. It a pain because my swampers have to come off and I have to roll there on the stock rubber. I have had it for 5 years now and everytime they do it. Only the rears spin. I don't think the system on a dyno conciders it slipping. I belive it kicks AWD when one wheel starts to spin faster that the other. Not front to rear but from right to left in the rear. slipping.
BigExpy, you might have to have a certain amount of posts before you can put something in your sig - I'm not sure.
However you can upload pics to a photobucket account and post 'em up. I think to put 'em in your gallery you have to have like 25 posts. Probably the same with adding to sig.
-rockstate
-rockstate
The PCM reads the front wheel speed sensors and compares them to the rear wheel speed sensor located inside the rear diff. If it determines that the rear wheels are turning faster than the front wheels it will activate the clutch inside the transfer case, which applies power to the front wheels, IF, your selctor switch is in the AWD position. Some early vehicle years (I don't remember which years - '98 and '99?) had a 2WD position on the selector switch, which prevents the front wheels from engaging. Maybe your vehicle has the 2WD position?
