Champion 7989 Spark Plugs - Page 3 - Ford Truck Enthusiasts Forums
Old 11-17-2014, 06:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
  #31
Old 02-06-2014, 10:04 PM
cb_13's Avatar
cb_13 cb_13 is online now
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
I would rather change motorcraft plugs at 100k than champions at every 30k. Just my preferance.
  #32
Old 07-22-2014, 06:18 PM
Youngray Youngray is offline
Youngray is starting off with a positive reputation.
Motorcraft
So did Motorcraft come out with a one piece? I'm about to replace my COP's and wanted to change the plugs while was I there.
  #33
Old 07-22-2014, 07:03 PM
ramhunter5877 ramhunter5877 is offline
ramhunter5877 is starting off with a positive reputation.
Hi way men
What did they do for all that money?
  #34
Old 07-22-2014, 08:44 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
This is a 6 year old thread with 32 previous posts before you posted, so to whom are you asking that question?
Stewart
  #35
Old 07-22-2014, 10:17 PM
rickh6155's Avatar
rickh6155 rickh6155 is offline
rickh6155 is starting off with a positive reputation.
Pulled the right head off, tapped out very gently the piece that broke off, and put everything back together. Very time consuming and thus very costly.
  #36
Old 07-22-2014, 10:23 PM
rickh6155's Avatar
Quote:
Not to my knowledge. The Champs are far superior in my opinion, and they are platinum plugs, so the replacement mileage is comparable to the OEM Motorcraft plugs. I'm on my second set now, and no major issues whatsoever. The first set even came out easier than the Motorcraft originals. I highly recommend them. Truck just turned over 200,000 miles an perking along just fine.
  #37
Old 07-22-2014, 10:24 PM
rickh6155's Avatar
Quote:
Champs are platinum as well. Same mileage interval on changeout as Motorcraft.
  #38
Old 12-11-2016, 04:51 PM
Ted928 Ted928 is offline
Ted928 is starting off with a positive reputation.
I just installed my second set of champions. I was replacing fuel injectors since I recently read that the 2005 had bad injectors which can destroy the motor so I figured it was a good time to change the plugs also. The first set had 60,000 miles and 6 years on them. I was glad that they are welded as it took a lot of torque to get them out, even using carb cleaner. I checked the gaps and they were less than 44 mils which means no opening. I tore one boot. Spraying WD40 down the center of the boot didn't help. Then I used a hard wire down the center of the boot to break the seal and then they came off.
Two different types of spark plugs? buddybar Modular V8 (4.6L, 5.4L) 0 11-23-2015 09:29 PM
5.4 spark plug replacement??? 's dentfxr Modular V8 (4.6L, 5.4L) 6 08-10-2013 06:51 PM
2006 F250 spark plug change - success! AK 440 1999 to 2016 Super Duty 19 02-20-2013 12:45 PM
Champion,autolite,or motorcraft plugs..and part#question rferoni 2004 - 2008 F150 11 12-30-2009 10:13 AM
5.4L Champion Plug Gap motown 2004 - 2008 F150 4 07-06-2008 09:09 PM
Tags
2005, 3v, 54, 54l, 68l, 7989, champion, f150, f350, gap, plug, plugs, proper, properly, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
