Bad knock. Stranded on side of interstate
FWIW, a 'Stuck' injector to me means the P&B are jambed together which means the injector simply won't fire. No other symptoms other than a miss.
If a nozzle splits, then it'll pump fuel into the cylinder all the time whether or not the cylinder can burn it. This casues a slight miss and the truck smokes quite a bit of white smoke, but once the motor shuts off, there's no more fuel being pumped so it doesn't hydrolock the motor. I have worked on several trucks with split nozzles and this has always been the case, but I guess anything is possible. It would be new to me.
My money is on bent push rods or broken rocker arms, most likely push rods. I have read this happen quite a bit over the last 6 months and I'm beginning to wonder why...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
i had one rocker that seemed a little off when i changed them. I think it got damaged when a mushroomed gp dropped in w/o knowing and jammed in top of piston. I didnt see any wear after 15,000miles so figured it was ok.
I guess im pulling vc this weekend and if cant find anything ill get someone to trailer me home
no not yet its snowing/ raining here and i dont have a shop. I think i will have access to one on sunday.
It worked out pretty good. My buddy that lives in allentown was going to bring trailer up but only had an 18' which is too short. turns out he was in baltimore county today looking at a bale bandit. So he is stopping by the farm on his way back to pick up one of our extra truck and trailers and bring it up with his truck loaded saturday night. So now he gets his truck up here and i have our truck and trailer to get mine back and i dont have to wait for him to finish his finals or make him come an extra hour south
#30
diggintrenches
01-02-2015 06:36 AM
RedDevil460
53
03-29-2014 08:16 PM
