Are 265-75R15 the same as 31x10.5r15
Yeah they're the same size. 265 millimeters is section width, the widest part of the tire halfway up the sidewall. 75 means that the sidewall is 75% as tall as the section width. So the sidewall is 75% of 265, or 199 millimeters tall. Two sidewall heights plus the rim height will give you the height of the tire, or 2*199 millimeters + 15 inches. 398 millimeters divided by 25.4 millimeters per inch = 15.65 inches, + 15 inches = 30.65 inches. And 265 / 25.4 = 10.43 inches of section width. So it's a 30.65 x 10.43R15, although due to the undersizing involved in tire sizes it usually ends up identically to a 31x10.50. The wierd part is, since rim size comes into account in the height of a metric sized tire, flotation sizes like 31x10.5R15 and a 31x10.5R16 would be the same height, but a 265/75R16 is an inch taller than a 265/75R15.
phoneman91
05-11-2017 01:57 PM
f142f142
06-21-2011 01:08 AM
Trickedout420
03-06-2007 12:29 AM
wgm114
10-11-2002 10:01 PM
