excursion door panel removal - Ford Truck Enthusiasts Forums
Old 12-11-2008, 10:51 AM
chaserfish chaserfish is offline
chaserfish is starting off with a positive reputation.
i would like to know how to remove the inside door panels on my 2000 excursion xlt. i need to service th epower loks and windows. thanks
Old 12-11-2008, 11:32 AM
71-4R3SONS's Avatar
71-4R3SONS 71-4R3SONS is offline
71-4R3SONS has a good reputation on FTE.71-4R3SONS has a good reputation on FTE.
The Tech folder at the top of the forum has a write up on the process...
Plus, the SEARCH function on this site works rather well... I remember seeing a write-up (Joe posted it) with pics.
Old 12-11-2008, 11:49 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy X_Hemi_Guy is offline
X_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputation
See post #10 of this thread for the pictures that Bob is referring to...
http://www.ford-trucks.com/forums/79...-problems.html
Old 12-11-2008, 11:51 AM
thanks for the reply 71-4r3sons. I saw the tech folder and it is just what i was looking for.thanks again.
Old 12-11-2008, 12:12 PM
JaySVX's Avatar
JaySVX JaySVX is offline
JaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to all
The tech folder is great, there's a lot of really helpful info in it. When I have some free time I just read it for the hell of it.
Old 12-11-2008, 12:50 PM
1 Excursion camper's Avatar
1 Excursion camper 1 Excursion camper is offline
1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of
Of course it`s just as easy to say there are 2 screws that hold the panel on. one behind the light in the lower part of the door panel and one under the window switch bezel, the bezel pops out from the front first. also be sure to remove the trim piece for the mirror srews. then just lift up on the door panel.
Old 12-11-2008, 05:40 PM
BAJI26 BAJI26 is offline
BAJI26 is gaining momentum as a positive member of FTE.
I checked mine today and all bolts were pretty much tight but the window runs really smooth with the panel off. Any thoughts!?
Old 12-11-2008, 06:03 PM
sddesigns's Avatar
sddesigns sddesigns is offline
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
Quote:
Picture is worth a thousand words, this was just posted a couple of days ago.
Door panel removal
Old 12-11-2008, 11:01 PM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Quote:
Spray the inside channels(one at the front and one in the rear of the door), and the mechanisms with silicone spray. Sometimes a little bit of candle wax rubbed onto the panel channel that rubs against the glass solves the problem.(or like was suggested in the other thread, waxing the inside of the glass.) The wax doesn't leave any residue after for stuff to stick to, to scratch the glass when being moved up and down.
Old 12-12-2008, 07:37 AM
Quote:
I meant to post this in the other thread, the only think that really worked for me was engine oil which lasts for over a year.
Can someone move my post to the other window problem thread!
Door panel light woody367 1999 to 2016 Super Duty 7 09-15-2014 06:12 PM
door panel removal billy13 1997-2006 Expedition & Navigator 2 12-14-2009 10:29 AM
Door Panel removal dmcenery 2004 - 2008 F150 1 10-25-2008 09:52 AM
removing door panel on a 2003 f150 tutiii 1997 - 2003 F150 2 09-17-2007 09:41 AM
98door panel removal vinman46 1997 - 2003 F150 8 06-24-2004 06:58 PM
Tags
2000, 2001, 2002, diagram, door, excursion, ford, inside, panel, rear, removal, remove, removel, removing, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
