oil leaking from cooleer
Old 12-11-2008, 09:56 AM
iduger's Avatar
iduger
iduger is offline
Have oil leaking from front oil cooler . Any one ever have any issues with this. I am in houston any know of a reputable repair shop.
Old 12-11-2008, 10:28 AM
Suber's Avatar
Suber
Suber is offline
Which cooler are you talking about? Do you have an add-on tranny cooler up front, or a stock ford tranny cooler.
Old 12-11-2008, 01:17 PM
iduger's Avatar
iduger
iduger is offline
Its the cooler tube on the engine block.
Old 12-11-2008, 01:27 PM
Action4478's Avatar
Action4478
Action4478 is offline
I got a reman on ebay ,a couple hundred ..& a couple hours of work ,,,
Of course ,yours might not be rusted to heck like mine was ....
Pics of repair ...here....
Old 12-11-2008, 01:33 PM
ron86toy's Avatar
ron86toy
ron86toy is offline
in this link go to pg 31-32....the cooler has a couple o-rings......International part #'s are on pg 32
http://www.thedieselstop.com/faq/949...veic_final.pdf
Old 12-11-2008, 02:59 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
Jaaaaaaackman is offline
Hey Action ,nice pics,,,,,,,,, couple questions for you were did the block heater come from? is it mounted in the cooler also? And how was it getting the cooler out, looks like a bear of a job with the motor in....... BTW I did a cooler rebuild on a 6.9 (they look the same) but the motor was out of the truck and just wondered if it was doable with motor in truck?
iduger give the cooler tube a good check for rust, mine let loose with a pin hole and was a t an idle for several minutes before I knew there was a leak and the engine pumped out at least 5 quarts of oil before I got it shut off,,,,,
Old 12-11-2008, 03:45 PM
Action4478's Avatar
Action4478
jaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaakman..
The reman came with the heater coil installed
mine was simple R&I .TJ said on his 95 he had to lift the motor ,,I did not ...
Old 12-11-2008, 07:29 PM
Jaaaaaaackman
7 A's aaaaaaa ,,,,,,, tried to sign up as Jackman and the site said name taken so I kept adding an A until I got the the A OK from the site .....
Yea I did not know that the block heater on a PSD was in the cooler,,,,,, nice to hear that you got it out with out lifting the motor, will remember that for when the cooler r&r comes up again.....
Thanks for the info........
Old 12-11-2008, 07:35 PM
Action4478's Avatar
Action4478
I wondered if you counted them....
Old 12-11-2008, 07:40 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
I did lift the motor and inch or so on that side on my 95 but when I did my cooler reseal on the 97 not long ago it came out without lifting. But it took lots of wiggling!
Old 12-14-2008, 09:23 PM
iduger's Avatar
iduger
iduger is offline
oil cooler r&r
Anybody know the order to remove the cooler and other parts that might need to be removed. Do i need to remove all the coolant ? Any helpful tips would be greatly appreciated. Thanks for everyones help.
Old 12-15-2008, 07:50 AM
Action4478's Avatar
Action4478
I removed & saved my (fresh) coolant & drained the oil the day before ,,& left the oil drain plug out ,in case any water got in the pan later. I raised the left side of the truck a bit ,to aid draining .I removed the front cooler bolts first with a very long extension through the left front wheel opening,,then the rear after removing the filter ,removed the assembly ,,there was very little mess ...
crackerloco
Aerostar
18
12-26-2017 12:54 PM
wes.r
01-29-2011 05:02 AM
ryansmo
02-26-2008 10:55 PM
ford390gashog
11-20-2004 10:35 PM
redygo
02-12-2004 08:39 PM
Quick Reply: oil leaking from cooleer
