Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-10-2008, 11:15 PM
Old Ford Blue's Avatar
Old Ford Blue Old Ford Blue is offline
Old Ford Blue is starting off with a positive reputation.
1bbl carbs
Where to start? I guess I'll get right to the question, I've got a 64 Ranchero that has a 68 or 9 200-6 in it. I believe the original carb was an autolite 1100, what is on there now is a Carter YF, the problem is that said carb is having major fuel issues(dumping way to much fuel down the intake, even with it leaned to within half a turn.) So I went to pick up a rebuild kit, well Advance can't even order a rebuild kit for the YF, and didn't even list the 1100 or it RR kit. They could only order me a 140$ YF.
What are yall doing to get around this???
Thanks in advance!
__________________
Gabe
67 F-100 Ranger Hipo 390 4bbl\3 speed
73 F-100 Custom 302\auto---The best part is....it was FREE!
along with several other trucks and jeeps.
__________________
I decided that if the assembler could get stoned and put these trucks together, I should have no problem fixing them. LOL
__________________
  #2 (permalink)
Old 12-11-2008, 03:39 PM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE.
Rebuild kit $32.50 at willysjeepparts.com probably available at other Jeep outlets also. However sounds like either your float level is too high or the float valve needs cleaned. Good luck.
  #3 (permalink)
Old 12-12-2008, 06:50 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Some of the 1967/72 200's used Auto-Lite carbs, some used the Carter YF carb, it depended on the application.
Example: 1967/68 200 I-6 Falcons, Fairlanes and Mustangs with C4 trannies, without a smog pump used the Carter carb, while the same cars with a smog pump used the Auto-Lite carb.
C7DZ9A586C .. Carburetor Tune-Up Kit (Motorcraft CT201A) / Obsolete
Bowman Sales & Service (Ford Dealer) in Bowman ND has one = 701-523-3257
Obsolete parts vendor Green Sales Co in Cincinnati OH has three = 800-543-4959.
Since the kit is obsolete, the Ford dealer is STUCK with it, so you might be able to buy it at dealer net (cost), which was around 12 bucks as I recall.
This same carb kit fits: 1967/72 170 & 200 I-6 Falcon/Fairlane/Torino/Mustang/Maverick/Comet/Bronco w/Carter carbs
__________________
Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
  #4 (permalink)
Old 12-12-2008, 08:21 PM
Hey thanks a ton guys! And some great info as well ND. This particular 200 has no egr or smog pump.
I did manage to find a rebuild kit at the local O'Reilys for 14$ and it was in stock, so I can't complain.
The even better news is that "Randy" is running like a champ once again. The issue was a cracked accel pump. I had originally thought float level as well but after adjusting that with no change I figured it was something else in the carb.
Thanks a ton guys!
Gabe
__________________
Gabe
__________________
__________________
  #5 (permalink)
Old 12-18-2008, 05:55 PM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
just something to think about. HotRod magazine did an article last year on a Maverick that a company who sells fuelinjection mapping software put a throttle body injector off a Chrysler K car's 2.6L Mitsubishi four. Drivabilty was great and MPG and HP both went up. 26mpg, I think the story is on the web site.
  #6 (permalink)
Old 12-20-2008, 08:18 PM
Now that is some good info, definitly something to look into.
Thanks for the info!
__________________
Gabe
__________________
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
