Quick Strut Removal Question.
What are you working on? Most have 2-3 nut/bolts on the top of the strut tower, remove them along with the bolts that connect it to the knuckle and anything else that might be attached to the strut (wires, hoses). Just don't mess with the center nut until you have the spring compressed. Some however such as some Saabs, GM A bodies (Ion, Colbalt, G5) have only a center nut on top of a center nut.
on
1 Post
unless you are taking the spring off the strut, you dont compress anything - all compression is removed for your purpose by jacking it up.
usually 2 bolts at the base into the knuckle, and 3 bolts at the upper strut tower bushing.
RSCHAP1
07-23-2008 02:00 PM
