'96 5.8 stock injector size? - Ford Truck Enthusiasts Forums
Old 12-10-2008, 02:19 PM
Jimn8or Jimn8or is offline
Jimn8or is starting off with a positive reputation.
This is an OBD ll, roller 5.8. I need to know what the stock injector size is for this engine. I always thought they were 19's but someone just sold me a set of Motorsport 24's absolutely certain that this is a stock replacement fuel injector. Who knows for certain...or where I can find out for certain?
Thanks,
Bob
Old 12-10-2008, 02:23 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
The stock injector size was 19lbs per hour. You could step up to the 24lb/hr but I don't think it'll do much good.
Old 12-10-2008, 03:21 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The Lightning motor used the blue 24lb squirters, but the regular 5.8 used the orange 19lb version. Swapping these on an otherwise stock motor will produce drivability problems and codes too I bet.
Old 12-10-2008, 03:28 PM
My orange injectors have p/n F2TE-A3A. These corrospond to a 19lber on some listing I found. Back to the parts store to exchange. I should've gone with my gut...
Thanks for the replies.
Old 12-10-2008, 07:35 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
From what I've read, the lightning used 19lb injectors as well, and only the 460 used 24lb injectors. The 24's will have blue tops and exterior size wise will fit in place of the 19's. As already mentioned, this isn't such a good idea without tuning.
Old 12-11-2008, 12:47 AM
pfogle's Avatar
It just make the truck run rich. Like the computer could lean it out enough, but then you've wasted money on larger injectors that aren't doing you any good.
5.8 HO - whats the difference? Bobcat7 Performance & General Engine Building 14 06-16-2016 06:36 PM
What exactly kind of power Paul Peavey Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 07-31-2015 11:45 PM
Fuel injector questions Chris71Mach1 1997-2006 Expedition & Navigator 3 03-10-2015 05:57 PM
Fuel system maintenance/upgrades the_auto_tech 6.0L Power Stroke Diesel 5 01-20-2015 02:26 PM
Fuel system maintenance and upgrades - complete list the_auto_tech 6.0L Power Stroke Diesel 31 07-05-2013 10:38 AM
Tags
24lb, 460, 58, 97, f150, f2tea3a, f350, ford, fuel, inectors, injector, injectors, lbs, lightning, size, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
