HELP!!! fuel filter schrader valve? Air in?
My father recently bought a 6.9 powered 350. Thinks he ran out of fuel no start.
He was told to "pressurize" the tanks by blowing air in the schrader valve....
was he mislead and what exactly are the uses of the valve besides testing pressure with a gauge? What shall we do now that he has run air in?
He is on the way to pick me up so any fast replies win!
Brent
Brent
The valve is to let air out as the pump sucks the fuel from the fuel tanks, and sends it up to the filter. If you have one of those little tools that unscrews the guts of the valve, take that and remove the guts from the valve,(or unscrew the whole valve out of the block) and then crank the engine till you get fuel coming out of the valve. Stop and replace the valve, and then a few more tries it should start sputtering and will start eventually. Make sure to give the starter a rest between tries.
Well after getting there and getting charger on the batts, I had him crank it a few times 'tween resting the starter and re-upping the juice each time with the valve core opened. I cracked loose fittings to determine the lift pump was working... My dad even said "Lift pump? I thought the *fuel pump* did that..." I cracked the nut at the 2 rear most injectors and had him crank it until they were damp. Well I finally got hold of the handy dandy hand vac pump and brake bleeder kit. Sucked fuel a total of 8 ounces or so from the schrader until no bubbles and soaked some up on a clean rag much to pop's chagrin as he was SURE I was going to hydra lock his motor and as he cranked it I piddled a bit til she fired off! He asked why not just purge each injector then crank it... My reply was since his batteries were far from full and his starter would not survive long with low juice and cranking it was just the way I was going to do it! Now to convince the hard headed cuss that he NEEDS NEW BATTERIES and may as well put the starter money aside too!
Truck runs...
Brent
Truck runs...
Brent
IDIoit
04-05-2016 01:32 PM
artfd
01-01-2012 08:13 PM
