Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-08-2008, 08:09 PM
old farmer old farmer is offline
old farmer is starting off with a positive reputation.
3.0L 24 valve PCV valve
A little off topic but we have a 3 liter Duratec V6 in a 2001 Taurus.
Maybe the Escape would be similar.
I replaced a hard plastic tube that runs from the rear bank cam cover to the air intake just downstream of the air filter. It had rotted off at the cam cover and was causing a crankcase oil smell in the cab.
It cost $22 for a short piece of plastic pipe!
The other cam cover has a similar piece also connected to the air intake.
My question is: Where is the PCV valve? I didn't think it was in the cam cover because they both connect at the same area on the air intake, so there wouldn't be a differential in the vacuum to make air flow through the crankcase. I thought the valve would need to connect downstream of the throttle valve for it to work.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
