official steering wander thread
Same story here. early 99 CC SB. Adjusted steering box. New track bar bushings. Stock suspension. New Munroe shocks (wont make this mistake again). 285/75 R16 BFG current. 265/75 R16 Mich LTX previous. Still handles like every other solid front axle truck I've had. If it didn't have the wheelbase, it would be really sloppy. Hope to get some ideas here. Thanks
Link for Steering Symptom Chart CLICK HERE Scroll down about 5 screens for chart. Chart will have WANDER in condition column.
I haven't seen any mention of steering column u-joint issues.
MANY thanks forf above link. I just spent $500 with NAPA and replaced all tie rods, track bar etc. Ball joints were still good. That link is just what I needed for steering gear. In fact I came on to post and ask for info.
PS 317,000 mi on original s ain't shabby!!!
I went down this very familiar road w/ my 98' Dodge/Cummins 4X4 years ago...got it close (like my Ford is now...) but could never get it "perfect" like say...a 1/2 ton truck. I guess these straight axle trucks just only get so good per say, without driving us nuts
( I gota admit...the Duramaxes are a pleasure to steer )
Here's the link for the entire 99 manual. CLICK HERE Compliments of another FTE member.
Did you go to the link I put in post #8 for the steering problem symptom list and what to look for. Could list to make sure you didn't overlook anything.
Here's that LINK
Here's that LINK
If anyone has any feedback on my steering stabalizer please share. It's got about 60,000 miles on it. It's a Rancho. I took one end loose and can move the plunger in and out. It's firm but if it was a shock i would replace. I don't remember how stiff the stabalizer was when I put it on. I don't think that would correct the wandering but it might help a bit. Maybe what this is is a bunch of things being worn just a little but the sum of all of them creates the problem. If that's the case it would be a high dollar fix, that's for sure.
jeff I had that type of issue with my 97 I had, the problem with that was the actual steering column. There was a slip joint about mid way down the shaft under the hood. This slip joint was loose and had a few inches of play at the wheel end. it required a replacement to repair.
I apologize if these newer models are different, i have never looked at my '02 steering shaft. And if this has already been mentioned just ignore it lol.
Just a shot in the dark here, but in one of my former jobs I drove a 2002 F250 with a V10. Every time it went to the company shop for service, it came back with a terrible wander problem. I was able to solve the problem on that truck by lowering the front tire pressure a little. The servicman pumped them to Ford's suggested pressure, wandered all over, lowered to 55lbs (not sure, but I think that's correct) problem solved.
My present SD has no problem-----yet.
#28
Update..Update..Update
Hi all. I have spent a lot of time looking for a solution to this steering problem. I have now changed my diagnosis. My truck is not wandering, I have steering play and when driving it feels like we are wandering because the wheel has play. About 2 inches of play in each direction which is 4 inches total. That's a lot. Here's what i think i've found: at the bottom of the steering shaft there is a universal joint just as the shaft enters the steering box. To see that, slide a plastic cover up the shaft. The cover is secured by a split ear which goes around one of the fluid lines going into the steering box. I got at mine over the drivers side wheel, just reached in and slid the cover up towards the firewall. Once i could see it I got my helper (wife) to start the truck and turn the wheel slowly back and forth. With one hand on the steering shaft and one on the pitman arm I can feel the play (i think). I say I think because I can't find any refrence to a ratio of in to out by the steering box. Another thing I've found is the adjustment I had done last at the dealership is on the invoice as a "preload" adjustment. Is that a different adjustment than the "meshload" adjustment? If so how is it adjusted? Thanks, Stan
#29
you have documented the exact problem that I have been complaining about. Now we just need to see where the play is located at. I have head enough excuses for poor engineering, bad geometry, poor factory tire size recommendations, etc. This thread it to help identify the difference between the less than 100k mile trucks that seem to steer fine and the post 100k mile trucks that are all over the road. I have not yet been able to find where the steering wheel slop comes into play and my arms are not long enough to move the wheel and hold the shaft under the hood to see if there is play in the steering shaft itself.
#30
