Exploded view of 54 F100 Clutch/Brake - Ford Truck Enthusiasts Forums
Old 12-08-2008, 05:05 PM
lowtrkn2k's Avatar
lowtrkn2k lowtrkn2k is offline
lowtrkn2k is starting off with a positive reputation.
Question Exploded view of 54 F100 Clutch/Brake
Does anyone have a view of the clutch and brake setup. I pulled mine out of my pile of parts and I need to see how it goes together and attaches to the frame.
Old 12-08-2008, 07:30 PM
turnrjr turnrjr is online now
turnrjr is starting off with a positive reputation.
Low I tried but coulnd't attach a picture. A common problem on this site.
Bob
Old 12-08-2008, 07:52 PM
Low
Google Kevin's 1953 F100. Go to project Archives. Clutch Rebuild July 2005. He has a good picture of the linkage.
Bob
Old 12-08-2008, 09:34 PM
bnradams's Avatar
bnradams bnradams is offline
bnradams is starting off with a positive reputation.
Here's the pic and a link to the page, (some web pages leave off the file extension in the properties tab, I was able to paste this one and add ".jpg" to the end and it worked.)
https://netfiles.uiuc.edu/kkessler/w...ch_rebuild.htm
Old 12-08-2008, 10:45 PM
lowtrkn2k's Avatar
Thanks guys. What is the "U" shaped (not sure what it's called) thing attached to on the left? Mine wasn't together when I got it so I'm having to figure out how this thing goes together.
Old 12-09-2008, 12:23 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Hi there Low!
Well, I'm familiar with the picture posted above because it's part of a series that were posted for an Overdrive Transmission on an IL6 thread we just ran through.
To answer your question, the "U" shaped thing is attached to a "clutch release equalizer bracket" (7507 in the top picture in my next post) which is bolted to the side shifter plate on the transmission just above the shift levers. The "U" shaped thing is called the clutch release equalizer (or something close) (7572 in the second picture in my next post) Those two pieces bolt together with a sliding bolt so that 7572 can pivot when th eclutch pedal is pushed.
Funny thing about this picture is it's installed upside down if in fact that is a 3spd. They were installed that way on the 5 spds.
I have two exploded drawings I can post, but I have to scan them and put them in my gallery. I'll be back in a minute.
J!
Old 12-09-2008, 12:43 AM
lowtrkn2k's Avatar
Thanks Julie. Im going to be using this with a T5 from a Mustang so I'll have to figure out how to set it up.
Old 12-09-2008, 12:56 AM
Ok,
But just FYI, here's the pics - maybe they will help. About all you'll have to do is make a new bracket and figure some way to attach it to the T5.
Good Luck,
J!
PS I edited in a few comments in my post #6 above for clarification.
Old 12-09-2008, 10:53 AM
low54's Avatar
low54 low54 is offline
low54 is starting off with a positive reputation.
Hello, noe that we're talkin 'bout this, how about the spring w/ the long neck #7523 I'm haven trouble attaching that, I thought I took good enough pics but Nope always mess up one!
Old 12-09-2008, 11:02 AM
Quote:
You have to stand on your left foot when you do it. Havi says chewing gum helps but I've never tried that personally!
J!
Old 12-09-2008, 11:30 AM
low54's Avatar
Cool f1 U kill me...LOL
Old 12-12-2008, 01:44 PM
Fat Fendered Ford's Avatar
Fat Fendered Ford Fat Fendered Ford is offline
Fat Fendered Ford is starting off with a positive reputation.
Quote:
Originally Posted by Julies Cool F1 View Post
Hi there Low!
I'll be darned. Never noticed that. Guess I'll have to take care of that next time I'm out in the shed. Doesn't seem to affect its operation, though!
Old 12-12-2008, 09:34 PM
Quote:
I wouldn't think that it would....basically you are just rotating around that hole that bolts up the "U" anyway, so that hole is in the same position.
The only reason I brought it up is I noticed in the picture you didn't have the shifters hooked up yet and I was thinking that perhaps it might have interfered with the back shifter later on and yo might have flipped it back at that point.
When I take pictures of things as I'm putting them back together, sometimes I will mis install a part, then have to correct it later on in the assembly...But I don't remember to mention it in the pictures.
If it works ok - go for it....I love these trucks, they are so forgiving!
Julie!
Old 12-15-2008, 09:17 AM
19fifty4 19fifty4 is offline
19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of19fifty4 has much to be proud of
Hopefully you won't mind if I ask a question while the discussion is on the brake/clutch assembly especially since there is a nice pic to reference. I'm trying to detach the entire assembly from the frame. I've got it loose but can't figure out what to take off so I can slide it through the frame rail. I'll try to take a pic and post. Thanks.
Old 08-06-2015, 08:47 PM
Highdefcowboy's Avatar
Highdefcowboy Highdefcowboy is offline
Highdefcowboy is starting off with a positive reputation.
Pics and links
The pics and links mentioned above seem to be not working - not available
What I have done to my 1985 F250 5.0L Hopsing69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-04-2016 01:37 PM
'97 b4000 clutch master cyl seagull369 Ranger & B-Series 4 10-13-2015 11:12 AM
Fan Clutch Wiring KRDiesel 6.0L Power Stroke Diesel 19 09-19-2015 12:01 AM
removing clutch pedal arm issues crystalhand 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-29-2015 12:13 PM
1971 i6 cross member master link 1967 - 1972 F-100 & Larger F-Series Trucks 4 06-25-2015 01:32 PM
Tags
1953, 1981, 48, 53, 54, assembly, brake, clutch, customline, drawings, f100, ford, pedal, setup, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
