Compass Zones - Ford Truck Enthusiasts Forums
Compass Zones
Old 12-08-2008, 02:14 PM
dfishrmn88's Avatar
dfishrmn88 dfishrmn88 is offline
dfishrmn88 is starting off with a positive reputation.
Compass Zones
I recently pushed the trip odometer button to reset and ended up in the zone selector. I searched other threads and they said to set it to your zone from the manual. Well, I went to do that and it is stuck on "CAL". The threads didn't tell how you get back to the "zone" selector. Any advice?
Old 12-08-2008, 02:31 PM
SteveVFX4 SteveVFX4 is offline
SteveVFX4 is starting off with a positive reputation.
I think you might have already picked some zone, and for the CAL part, you have to drive around in a circle slowly so that it can calibrate itself. Re-read your manual about that part. After you get out of CAL, then you go can go back through the steps to make sure you pick your correct zone.
Old 12-08-2008, 02:55 PM
dfishrmn88's Avatar
Thanks! I just went out and tried that. It recalibrated but when I went to pick the zone it went back to "CAL" mode. Am I missing something to get back to the "zone" area. When this first happened I left it at zone 5 and I need to be in zone 7 according to the manual.
Old 12-08-2008, 03:08 PM
I can't remember for sure, it tells you in the manual, so re-read those steps closely. I did this before too like you, accidently, and I followed the steps in the manual to recalibrate my zone area. I just remember the CAL part about driving around in a circle, but I don't have the manual in front of me to tell you all the steps.
Old 12-08-2008, 05:34 PM
Buck 1 Buck 1 is offline
Buck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to behold
SteveVFX4 is exactly right: once you drive around in the circle slowly it will advise you that the calibration mode is finished. Then, you can go thru the necessary steps to get the correct zone, but you may have to calibrate it again after setting the proper zone.
Old 12-09-2008, 11:02 AM
dfishrmn88's Avatar
I finally got it back. I missed the step from the manual where you press the reset button for 6 seconds and RELEASE. Setting it to the CAL setting and then driving in a circle re-calibrated just like you suggested. Thanks for the help!
Old 12-09-2008, 11:18 AM
mrpositraction's Avatar
mrpositraction mrpositraction is offline
mrpositraction is gaining momentum as a positive member of FTE.
So what are the different zones? I accidently pushed it while on a trip and never messed with it again. I will have to read the owners manual and see what zone I am supposed to have.
Old 12-09-2008, 11:21 AM
dfishrmn88's Avatar
The zones are for different magnetic fields and vary across the nation. They were on page 80 & 81 in my manual (2005).
EGT danger zone? Shattered 1999 - 2003 7.3L Power Stroke Diesel 8 06-25-2014 10:22 AM
Install Dual Zone Climate Control in 2008-2010 XLT? CKetchum 6.4L Power Stroke Diesel 1 02-25-2014 07:30 AM
What do the zone #'s 1 -15 mean? Crazyotto1 1999 - 2003 7.3L Power Stroke Diesel 2 02-07-2014 02:34 AM
Fuel Tank Selector Valve dakotajeep Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 35 01-01-2014 06:23 PM
Cluster says zone and a number??? HELP ASAP!!! GrizzlyMan660 2004 - 2008 F150 2 01-12-2012 09:28 PM
Tags
2004, 2005, 2007, cal, calibrating, calibration, compass, f150, f250, ford, magnetic, odometer, stuck, working, zone, zones
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
