Speed Sensor Location on 2003 Expedition - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 12-08-2008, 01:17 PM
kcmark kcmark is offline
kcmark is starting off with a positive reputation.
I am doing a self install of a Pioneer AVIC F900BT on a 2003 Expedition and need help finding the Speed sensor wire. Any help would be appreciated. Also, is there any location closer to hook up the reverse signal without going all the way to the taillight?
Thank you in advance.
Old 12-09-2008, 02:29 AM
c_hohensee c_hohensee is offline
c_hohensee is starting off with a positive reputation.
If you know the color of the wire you could find the speed sensor wire at the cruise control module under the hood.
Old 12-09-2008, 07:40 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
On the 03 Expedition, the VSS signal is already present on the GRAY/BLACK wire, either pin 9 or pin 14, in the 20 pin head unit connector.
There was a running production change that changed the pin assignment during the model year.
Steve
Old 12-09-2008, 10:27 AM
Head Unit
Sorry for not being so technical, but when you refer to the head unit, you are talking about the wire assembly that is already going into the back of the radio? Thanks again.
New TPMS sensors on a 2003 Expedition smwdouglas 1997-2006 Expedition & Navigator 1 06-15-2016 08:07 AM
Camshaft position sensor location ??? Charlie Tee Ranger & B-Series 1 09-14-2015 07:36 PM
crankshaft postion sensor chosen69 1997-2006 Expedition & Navigator 1 01-29-2015 09:05 PM
2003 expedition door ajar problem texasman 1997-2006 Expedition & Navigator 6 12-05-2013 12:12 PM
ICP Sensor Attilak1 6.0L Power Stroke Diesel 16 07-31-2010 04:36 PM
Tags
03, 2001, 2003, 98, control, expedition, ford, location, replacement, sensor, signal, speed, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
